    Retropie 4.3 & Kodi 17.4 package No Sound with passthrough
    kodi retropiepassthroughkodi 17.4
    14 Posts 3 Posters 3.0k Views
      BU3304
      Hello,
      New on Retropie, I encounter a worry with Kodi : I no longer have audio via passthrough. Works perfectly with my Openelec build (Kodi version 17.3) or with my recalbox 4.1's micro sd (Kodi 16). I removed the kodi package via retropie menu and deleted folder Kodi in Ports. Always the same worries. I wish to stay on Retropie because more powerful and especially more personalizable than recalbox or batocera. Waiting for an answer. Thanks in advance.
      RascasR 1 Reply Last reply Reply Quote 0
      • RascasR
        Rascas @BU3304
        @bu3304 Which settings did you change in audio and video sections to enable passthrough? Make sure you have "Sync playback to display" disabled, otherwise passthrough wont work, this was introduced in Krypton.
          BU3304 @Rascas
          @rascas
          Thank you for your answer. The option is disabled by default. No sound via passthrough.
          Its OK under retropie and in kodi menus but no sound when I play a movie with ac3 or dts.
          I don't understand.
          • RascasR
            Rascas @BU3304
            @bu3304 that photo isn't clear but another thing that you should do is to set the number of channels to 2, no mather how many speakers you have. Here is guide for configuring this kind of things:
            http://kodi.wiki/view/audio_quickstart_guide
            Also I suggest you start with default settings, for that remove /home/pi/.kodi dir, in RetroPie it is symlinked to another dir which I cannot confirm right now because I dont have one at hand right now.
            If after that still dont have passthroug, please a Kodi debug log:
            http://kodi.wiki/view/Log_file
              BU3304 @Rascas
              @rascas Thank you, I try your advice.
                BU3304
                Hello. Your advice did not work. No sound via Passthrough. Pity.
                I will try to put the kodi log file. In the meantime I switch with my Openelec micro sd card
                • RascasR
                  Rascas @BU3304
                  Passthrough is working, I just tested myself. The AV receiver also shows correctly the source audio format, as always.
                  The debug log should help identify your problem.
                    BU3304 @Rascas
                    This post is deleted!
                      BU3304
                      @bu3304 said in Retropie 4.3 & Kodi 17.4 package No Sound with passthrough:
                      @rascas Hi. How make debug log ? Because Kodi works perfectly on other distributions
                      Sory, I tray this : http://kodi.wiki/view/Log_file/Easy
                      My Log :
                      7:13:57.672 T:1945678496  NOTICE: special://profile/ is mapped to: special://masterprofile/
                      17:13:57.672 T:1945678496  NOTICE: -----------------------------------------------------------------------
                      17:13:57.672 T:1945678496  NOTICE: Starting Kodi (17.4 Git:20170913-5cc491e-dirty). Platform: Linux ARM 32-bit
                      17:13:57.672 T:1945678496  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
                      17:13:57.672 T:1945678496  NOTICE: Kodi compiled Sep 13 2017 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
                      17:13:57.673 T:1945678496  NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.9.35-v7+
                      17:13:57.679 T:1945678496  NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
                      17:13:57.679 T:1945678496  NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
                      17:13:57.679 T:1945678496  NOTICE: ARM Features: Neon enabled
                      17:13:57.679 T:1945678496  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
                      17:13:57.679 T:1945678496  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
                      17:13:57.680 T:1945678496  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
                      17:13:57.680 T:1945678496  NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
                      17:13:57.680 T:1945678496  NOTICE: special://envhome/ is mapped to: /home/pi
                      17:13:57.680 T:1945678496  NOTICE: special://home/ is mapped to: /home/pi/.kodi
                      17:13:57.680 T:1945678496  NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
                      17:13:57.680 T:1945678496  NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
                      17:13:57.680 T:1945678496  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin
                      17:13:57.680 T:1945678496  NOTICE: Local hostname: retropie
                      17:13:57.680 T:1945678496  NOTICE: Log File is located: /home/pi/.kodi/temp//kodi.log
                      17:13:57.680 T:1945678496  NOTICE: -----------------------------------------------------------------------
                      17:13:57.760 T:1945678496   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
                      17:13:57.849 T:1945678496  NOTICE: load settings...
                      17:13:58.014 T:1945678496  NOTICE: Found 2 Lists of Devices
                      17:13:58.014 T:1945678496  NOTICE: Enumerated PI devices:
                      17:13:58.014 T:1945678496  NOTICE:     Device 1
                      17:13:58.014 T:1945678496  NOTICE:         m_deviceName      : HDMI
                      17:13:58.014 T:1945678496  NOTICE:         m_displayName     : HDMI
                      17:13:58.014 T:1945678496  NOTICE:         m_displayNameExtra:
                      17:13:58.014 T:1945678496  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
                      17:13:58.014 T:1945678496  NOTICE:         m_channels        : FL,FR
                      17:13:58.014 T:1945678496  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
                      17:13:58.014 T:1945678496  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
                      17:13:58.015 T:1945678496  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
                      17:13:58.015 T:1945678496  NOTICE:     Device 2
                      17:13:58.015 T:1945678496  NOTICE:         m_deviceName      : Analogue
                      17:13:58.015 T:1945678496  NOTICE:         m_displayName     : Analogue
                      17:13:58.015 T:1945678496  NOTICE:         m_displayNameExtra:
                      17:13:58.015 T:1945678496  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
                      17:13:58.015 T:1945678496  NOTICE:         m_channels        : FL,FR
                      17:13:58.015 T:1945678496  NOTICE:         m_sampleRates     : 48000
                      17:13:58.015 T:1945678496  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
                      17:13:58.015 T:1945678496  NOTICE:         m_streamTypes     : No passthrough capabilities
                      17:13:58.015 T:1945678496  NOTICE:     Device 3
                      17:13:58.015 T:1945678496  NOTICE:         m_deviceName      : Both
                      17:13:58.015 T:1945678496  NOTICE:         m_displayName     : HDMI and Analogue
                      17:13:58.015 T:1945678496  NOTICE: Enumerated ALSA devices:
                      17:13:58.015 T:1945678496  NOTICE:     Device 1
                      17:13:58.015 T:1945678496  NOTICE:         m_deviceName      : @
                      17:13:58.015 T:1945678496  NOTICE:         m_displayName     : Default (bcm2835 ALSA bcm2835 ALSA)
                      17:13:58.015 T:1945678496  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000
                      17:13:58.015 T:1945678496  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
                      17:13:58.057 T:1945678496  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
                      17:13:58.057 T:1945678496  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
        <?xml version="1.0" encoding="UTF-8" ?>
        <advancedsettings>
        <fanartres>720</fanartres>
        <imageres>540</imageres>
        <video>
        <busydialogdelayms>750</busydialogdelayms>
        </video>
        <samba>
        <clienttimeout>30</clienttimeout>
        </samba>
        <cache>
        <memorysize>31457280</memorysize>
        </cache>
        </advancedsettings>
                      17:13:58.059 T:1945678496  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
                      17:13:58.059 T:1945678496  NOTICE: Default Video Player: VideoPlayer
                      17:13:58.059 T:1945678496  NOTICE: Default Audio Player: paplayer
                      17:13:58.059 T:1945678496  NOTICE: Disabled debug logging due to GUI setting. Level 0.
                      17:13:58.059 T:1945678496  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
                      17:13:58.059 T:1945678496  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
                      17:13:58.061 T:1945678496  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
                      17:13:58.069 T:1945678496  NOTICE: Loaded playercorefactory configuration
                      17:13:58.069 T:1945678496  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
                      17:13:58.069 T:1945678496  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
                      17:13:58.121 T:1945678496  NOTICE: Running database version Addons27
                      17:13:58.325 T:1945678496  NOTICE: ADDONS: Using repository repository.xbmc.org
                      17:13:58.450 T:1945678496  NOTICE: Raspberry PI firmware version: Jul  3 2017 14:16:43
        Copyright (c) 2012 Broadcom
        version 4139c62f14cafdb7d918a3eaa0dbd68cf434e0d8 (tainted) (release)
                      17:13:58.450 T:1945678496  NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
                      17:13:58.450 T:1945678496  NOTICE: cache.memorysize: 30MB libass.cache: 0MB
                      17:13:58.450 T:1945678496  NOTICE: Config:
        arm_freq=1200
        audio_pwm_mode=1
        config_hdmi_boost=5
        core_freq=400
        desired_osc_freq=0x36ee80
        disable_commandline_tags=2
        disable_l2cache=1
        force_eeprom_read=1
        force_pwm_open=1
        framebuffer_ignore_alpha=1
        framebuffer_swap=1
        gpu_freq=300
        hdmi_channel_map=8
        hdmi_force_cec_address=65535
        init_uart_clock=0x2dc6c00
        lcd_framerate=60
        over_voltage_avs=0x124f8
        over_voltage_avs_boost=0x124f8
        overscan_bottom=48
        overscan_left=48
        overscan_right=48
        overscan_scale=1
        overscan_top=48
        pause_burst_frames=1
        program_serial_random=1
        sdram_freq=450
        temp_limit=85
        device_tree=-
                      17:13:58.450 T:1945678496  NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 75.000000 Hz
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 75.000000 Hz
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 1152 x 864 for display 0 with 1152 x 864 @ 75.000000 Hz
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 60.000000 Hz
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 59.940063 Hz
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 1280 x 960 for display 0 with 1280 x 960 @ 60.000000 Hz
                      17:13:58.452 T:1945678496  NOTICE: Found resolution 1280 x 960 for display 0 with 1280 x 960 @ 59.940063 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 75.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 60.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 59.940063 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 75.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1440 x 1080 for display 0 with 1600 x 1200 @ 60.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1440 x 1080 for display 0 with 1600 x 1200 @ 59.940063 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 60.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 59.940063 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970032 Hz
                      17:13:58.453 T:1945678496  NOTICE: Found (1920x1080@60.000000) at 41, setting to RES_DESKTOP at 16
                      17:13:58.453 T:1945678496  NOTICE: Checking resolution 16
                      17:13:58.746 T:1945678496  NOTICE: GL_VENDOR = Broadcom
                      17:13:58.747 T:1945678496  NOTICE: GL_RENDERER = VideoCore IV HW
                      17:13:58.747 T:1945678496  NOTICE: GL_VERSION = OpenGL ES 2.0
                      17:13:58.747 T:1945678496  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
                      17:13:58.747 T:1945678496  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
                      17:13:59.971 T:1808393136  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
                      17:13:59.974 T:1925182384  NOTICE: Running database version Addons27
                      17:13:59.976 T:1925182384  NOTICE: Running database version ViewModes6
                      17:13:59.981 T:1925182384  NOTICE: Running database version Textures13
                      17:13:59.992 T:1925182384  NOTICE: Running database version MyMusic60
                      17:14:00.009 T:1925182384  NOTICE: Running database version MyVideos107
                      17:14:00.014 T:1925182384  NOTICE: Running database version TV29
                      17:14:00.020 T:1925182384  NOTICE: Running database version Epg11
                      17:14:00.024 T:1945678496  NOTICE: start dvd mediatype detection
                      17:14:00.711 T:1945678496 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
                      17:14:01.165 T:1945678496  NOTICE: initialize done
                      17:14:01.165 T:1945678496  NOTICE: Running the application...
                      17:14:01.216 T:1945678496  NOTICE: starting zeroconf publishing
                      17:14:01.217 T:1945678496  NOTICE: starting upnp client
                      17:14:01.240 T:1678767024  NOTICE: ES: Starting UDP Event server on port 9777
                      17:14:01.240 T:1678767024  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
                      17:14:05.174 T:1581667248 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
                      17:14:06.486 T:1581667248 WARNING: Previous line repeats 1 times.
                      17:14:06.486 T:1581667248  NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/4QZWmFjTXyCnPpVTamnXWEezJAv.jpg
                      17:14:11.316 T:1730855856 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
                      17:14:14.611 T:1730855856 WARNING: Previous line repeats 1 times.
                      17:14:14.612 T:1730855856  NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/rVWywwQLlz6Qf2WgJXvemLqlJo3.jpg
                      17:14:40.416 T:1945678496  NOTICE: VideoPlayer: Opening: smb://DLINK-237DCD/Volume_1/Vidéos/Films/Spider-Man Homecoming (2017)/Spider-Man Homecoming (2017) (x265).mkv
                      17:14:40.416 T:1945678496 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
                      17:14:40.417 T:1615852464  NOTICE: Creating InputStream
                      17:14:40.449 T:1615852464  NOTICE: Creating Demuxer
                      17:14:40.766 T:1615852464  NOTICE: Opening stream: 0 source: 256
                      17:14:40.766 T:1615852464  NOTICE: Creating video codec with codec id: 174
                      17:14:40.766 T:1615852464   ERROR: CMMALVideo::Open : Video codec unknown: ae
                      17:14:40.766 T:1615852464  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: hevc
                      17:14:40.930 T:1615852464  NOTICE: Creating video thread
                      17:14:40.930 T:1368982448  NOTICE: running thread: video_thread
                      17:14:40.930 T:1615852464  NOTICE: Opening stream: 1 source: 256
                      17:14:40.930 T:1615852464  NOTICE: Finding audio codec for: 86019
                      17:14:40.930 T:1615852464  NOTICE: Creating audio thread
                      17:14:40.931 T:1360593840  NOTICE: running thread: CVideoPlayerAudio::Process()
                      17:14:40.931 T:1615852464  NOTICE: Opening stream: 2 source: 256
                      17:14:40.934 T:1368982448  NOTICE: CDecoder::Open - fmt:341
                      17:14:40.941 T:1360593840  NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, pass-through)
                      17:14:41.405 T:1368982448  NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41727
                      17:14:46.838 T:1945678496  NOTICE: CVideoPlayer::CloseFile()
                      17:14:46.838 T:1945678496  NOTICE: VideoPlayer: waiting for threads to exit
                      17:14:46.841 T:1615852464  NOTICE: CVideoPlayer::OnExit()
                      17:14:46.841 T:1615852464  NOTICE: Closing stream player 1
                      17:14:46.841 T:1615852464  NOTICE: Waiting for audio thread to exit
                      17:14:46.857 T:1360593840  NOTICE: thread end: CVideoPlayerAudio::OnExit()
                      17:14:46.857 T:1615852464  NOTICE: Closing audio device
                      17:14:46.890 T:1615852464  NOTICE: Deleting audio codec
                      17:14:46.891 T:1615852464  NOTICE: Closing stream player 2
                      17:14:46.891 T:1615852464  NOTICE: waiting for video thread to exit
                      17:14:46.938 T:1368982448  NOTICE: thread end: video_thread
                      17:14:46.938 T:1615852464  NOTICE: deleting video codec
                      17:14:46.978 T:1615852464  NOTICE: Closing stream player 3
                      17:14:47.084 T:1945678496  NOTICE: VideoPlayer: finished waiting
                      17:14:47.417 T:1945678496  NOTICE: CVideoPlayer::CloseFile()
                      17:14:47.417 T:1945678496  NOTICE: VideoPlayer: waiting for threads to exit
                      17:14:47.417 T:1945678496  NOTICE: VideoPlayer: finished waiting
                      17:14:47.418 T:1945678496  NOTICE: CVideoPlayer::CloseFile()
                      17:14:47.418 T:1945678496  NOTICE: VideoPlayer: waiting for threads to exit
                      17:14:47.418 T:1945678496  NOTICE: VideoPlayer: finished waiting
                      17:15:15.855 T:1945678496  NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
                      17:15:15.855 T:1945678496  NOTICE: Enabled debug logging due to GUI setting. Level 2.
                      17:15:15.856 T:1945678496   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
                      17:15:15.857 T:1945678496   DEBUG: ------ Window Init () ------
                      17:15:17.441 T:1925182384   DEBUG: Thread JobWorker 1925182384 terminating (autodelete)
                      17:15:17.441 T:1739244464   DEBUG: Thread JobWorker 1739244464 terminating (autodelete)
                      17:15:17.442 T:1730855856   DEBUG: Thread JobWorker 1730855856 terminating (autodelete)
                      17:15:17.500 T:1581667248   DEBUG: Thread JobWorker 1581667248 terminating (autodelete)
                      17:15:18.972 T:1945678496   DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
                      17:15:18.972 T:1945678496   DEBUG: OnKey: down (0xf081) pressed, action is Down
                      17:15:19.122 T:1945678496   DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
                      17:15:19.389 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:19.389 T:1945678496   DEBUG: OnKey: down (0xf081) pressed, action is Down
                      17:15:19.522 T:1945678496   DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
                      17:15:19.655 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:19.655 T:1945678496   DEBUG: OnKey: down (0xf081) pressed, action is Down
                      17:15:19.805 T:1945678496   DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
                      17:15:20.139 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:20.139 T:1945678496   DEBUG: OnKey: down (0xf081) pressed, action is Down
                      17:15:20.289 T:1945678496   DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
                      17:15:20.755 T:1945678496   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
                      17:15:20.905 T:1945678496   DEBUG: OnKey: return (0xf00d) pressed, action is Select
                      17:15:20.906 T:1945678496   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
                      17:15:23.639 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:23.639 T:1945678496   DEBUG: OnKey: up (0xf080) pressed, action is Up
                      17:15:23.772 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:24.022 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:24.022 T:1945678496   DEBUG: OnKey: up (0xf080) pressed, action is Up
                      17:15:24.139 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:24.305 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:24.306 T:1945678496   DEBUG: OnKey: up (0xf080) pressed, action is Up
                      17:15:24.439 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:26.055 T:1945678496   DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
                      17:15:26.061 T:1945678496   DEBUG: OnKey: left (0xf082) pressed, action is Left
                      17:15:26.222 T:1945678496   DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
                      17:15:27.644 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:27.644 T:1945678496   DEBUG: OnKey: up (0xf080) pressed, action is Up
                      17:15:27.790 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:28.167 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:28.167 T:1945678496   DEBUG: OnKey: up (0xf080) pressed, action is Up
                      17:15:28.323 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:30.432 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:30.432 T:1945678496   DEBUG: OnKey: up (0xf080) pressed, action is Up
                      17:15:30.531 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:31.575 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:31.579 T:1945678496   DEBUG: OnKey: up (0xf080) pressed, action is Up
                      17:15:31.732 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:32.016 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:32.016 T:1945678496   DEBUG: OnKey: up (0xf080) pressed, action is Up
                      17:15:32.115 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:32.483 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:32.484 T:1945678496   DEBUG: OnKey: up (0xf080) pressed, action is Up
                      17:15:32.581 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:33.093 T:1945678496   DEBUG: Previous line repeats 1 times.
                      17:15:33.093 T:1945678496   DEBUG: OnKey: up (0xf080) pressed, action is Up
                      17:15:33.206 T:1945678496   DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
                      17:15:34.406 T:1945678496   DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
                      17:15:34.406 T:1945678496   DEBUG: OnKey: right (0xf083) pressed, action is Right
                      17:15:34.539 T:1945678496   DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
                      17:15:35.722 T:1945678496   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
                      17:15:35.839 T:1945678496   DEBUG: OnKey: return (0xf00d) pressed, action is Select
                      17:15:35.839 T:1945678496  NOTICE: Disabled debug logging due to GUI setting. Level 0.
                      17:15:35.839 T:1945678496  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
                      17:16:22.969 T:1945678496  NOTICE: Samba is idle. Closing the remaining connections
                      17:16:36.865 T:1581667248 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
                      17:16:38.171 T:1581667248 WARNING: Previous line repeats 1 times.
                      17:16:38.171 T:1581667248  NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/s57qsSyKWdNh6VoyCr7gafJSj0v.jpg
                      17:16:38.472 T:1945678496  NOTICE: VideoPlayer: Opening: smb://DLINK-237DCD/Volume_1/Vidéos/Films/Wonder Woman (2017)/Wonder Woman (2017).mkv
                      17:16:38.472 T:1945678496 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
                      17:16:38.473 T:1624241072  NOTICE: Creating InputStream
                      17:16:38.501 T:1624241072  NOTICE: Creating Demuxer
                      17:16:38.841 T:1624241072  NOTICE: Opening stream: 0 source: 256
                      17:16:38.841 T:1624241072  NOTICE: Creating video codec with codec id: 28
                      17:16:38.850 T:1624241072  NOTICE: Creating video thread
                      17:16:38.850 T:1624241072  NOTICE: Opening stream: 1 source: 256
                      17:16:38.850 T:1599075248  NOTICE: running thread: video_thread
                      17:16:38.850 T:1624241072  NOTICE: Finding audio codec for: 86019
                      17:16:38.850 T:1624241072  NOTICE: Creating audio thread
                      17:16:38.850 T:1547166640  NOTICE: running thread: CVideoPlayerAudio::Process()
                      17:16:38.861 T:1547166640  NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 44100, pass-through)
                      17:16:47.109 T:1945678496  NOTICE: CVideoPlayer::CloseFile()
                      17:16:47.109 T:1945678496  NOTICE: VideoPlayer: waiting for threads to exit
                      17:16:47.111 T:1624241072  NOTICE: CVideoPlayer::OnExit()
                      17:16:47.111 T:1624241072  NOTICE: Closing stream player 1
                      17:16:47.111 T:1624241072  NOTICE: Waiting for audio thread to exit
                      17:16:47.133 T:1547166640  NOTICE: thread end: CVideoPlayerAudio::OnExit()
                      17:16:47.133 T:1624241072  NOTICE: Closing audio device
                      17:16:47.170 T:1624241072  NOTICE: Deleting audio codec
                      17:16:47.170 T:1624241072  NOTICE: Closing stream player 2
                      17:16:47.170 T:1624241072  NOTICE: waiting for video thread to exit
                      17:16:47.209 T:1599075248  NOTICE: thread end: video_thread
                      17:16:47.210 T:1624241072  NOTICE: deleting video codec
                      17:16:47.221 T:1945678496  NOTICE: VideoPlayer: finished waiting
                      17:16:47.575 T:1945678496  NOTICE: CVideoPlayer::CloseFile()
                      17:16:47.575 T:1945678496  NOTICE: VideoPlayer: waiting for threads to exit
                      17:16:47.575 T:1945678496  NOTICE: VideoPlayer: finished waiting
                      17:16:49.973 T:1945678496  NOTICE: VideoPlayer: Opening: smb://DLINK-237DCD/Volume_1/Vidéos/Films/Baywatch Alerte à Malibu (2017)/Baywatch Alerte à Malibu (2017).mkv
                      17:16:49.973 T:1945678496 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
                      17:16:49.974 T:1590055856  NOTICE: Creating InputStream
                      17:16:50.005 T:1590055856  NOTICE: Creating Demuxer
                      17:16:50.147 T:1590055856  NOTICE: Opening stream: 0 source: 256
                      17:16:50.147 T:1590055856  NOTICE: Creating video codec with codec id: 28
                      17:16:50.155 T:1590055856  NOTICE: Creating video thread
                      17:16:50.155 T:1590055856  NOTICE: Opening stream: 1 source: 256
                      17:16:50.155 T:1590055856  NOTICE: Finding audio codec for: 86019
                      17:16:50.155 T:1526207408  NOTICE: running thread: video_thread
                      17:16:50.155 T:1590055856  NOTICE: Creating audio thread
                      17:16:50.155 T:1624241072  NOTICE: running thread: CVideoPlayerAudio::Process()
                      17:16:50.156 T:1590055856  NOTICE: Opening stream: 2 source: 256
                      17:16:50.166 T:1624241072  NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, pass-through)
                      17:16:56.875 T:1945678496  NOTICE: CVideoPlayer::CloseFile()
                      17:16:56.875 T:1945678496  NOTICE: VideoPlayer: waiting for threads to exit
                      17:16:56.878 T:1590055856  NOTICE: CVideoPlayer::OnExit()
                      17:16:56.878 T:1590055856  NOTICE: Closing stream player 1
                      17:16:56.878 T:1590055856  NOTICE: Waiting for audio thread to exit
                      17:16:56.908 T:1624241072  NOTICE: thread end: CVideoPlayerAudio::OnExit()
                      17:16:56.908 T:1590055856  NOTICE: Closing audio device
                      17:16:56.942 T:1590055856  NOTICE: Deleting audio codec
                      17:16:56.942 T:1590055856  NOTICE: Closing stream player 2
                      17:16:56.942 T:1590055856  NOTICE: waiting for video thread to exit
                      17:16:56.975 T:1526207408  NOTICE: thread end: video_thread
                      17:16:56.976 T:1590055856  NOTICE: deleting video codec
                      17:16:56.980 T:1590055856  NOTICE: Closing stream player 3
                      17:16:56.987 T:1945678496  NOTICE: VideoPlayer: finished waiting
                      17:16:57.448 T:1945678496  NOTICE: CVideoPlayer::CloseFile()
                      17:16:57.448 T:1945678496  NOTICE: VideoPlayer: waiting for threads to exit
                      17:16:57.449 T:1945678496  NOTICE: VideoPlayer: finished waiting
                      17:16:57.449 T:1945678496  NOTICE: CVideoPlayer::CloseFile()
                      17:16:57.449 T:1945678496  NOTICE: VideoPlayer: waiting for threads to exit
                      17:17:04.318 T:1945678496  NOTICE: Storing total System Uptime
                      17:17:04.319 T:1945678496  NOTICE: Saving settings
                      17:17:04.339 T:1945678496  NOTICE: Saving skin settings
                      17:17:04.343 T:1945678496  NOTICE: stop all
                      17:17:04.344 T:1945678496  NOTICE: stop player
                      17:17:04.344 T:1945678496  NOTICE: ES: Stopping event server
                      17:17:04.344 T:1945678496  NOTICE: stopping upnp
                      17:17:04.415 T:1678767024  NOTICE: ES: UDP Event server stopped
                      17:17:04.498 T:1945678496  NOTICE: stopping zeroconf publishing
                      17:17:04.503 T:1945678496  NOTICE: stop dvd detect media
                      17:17:05.508 T:1945678496  NOTICE: clean cached files!
                      17:17:05.658 T:1945678496  NOTICE: closing down remote control service
                      17:17:05.658 T:1945678496  NOTICE: stopped
                      17:17:05.939 T:1945678496  NOTICE: destroy
                      17:17:05.939 T:1945678496  NOTICE: unload skin
                      • RascasR
                        Rascas
                        Please follow the link as described. Debug isn't enabled and it should be a link on the pastebin.
                        And first, make sure you have the default settings, only passthrough enabled, so no other settings can interfere. There is settings that can make passthrough not working.
                          BU3304
                          Hello. Finally I format my SD card and re-instal 4.3 retropie img.
                          Its ok under kodi 17 in passthrough mode now.
                          But I lost my personalizations (Nes Theme , background music, splashscreen, Remove Boot Text)
                            BuZz administrators @BU3304
                            @bu3304 remove your log or put it on pastebin. You are not following instructions.
                              BU3304
                              Hello.
                              After a long period of illness, I come back to my post. Because I want to enjoy my convalesence to play retrogaming.
                              Still the problem of passthroug but I just understand what triggers the problem: when I install the script for the backgroud music :
                              https://github.com/Rydra/bgm-for-es
                              If clean installation with just Kodi, it's OK but as soon as I activate the rydra's script, I find myself with 5.1 crunches under Kodi.
                              Sorry, I try to use debug log on kodi but i don't understand the operations.
                              • RascasR
                                Rascas @BU3304
                                @bu3304 So the problem is that script. Stopping the script before launching Kodi and then starting it again when you exit Kodi should work.
