    Controller won't work with NDS-games but works with NES-SNES-GB-games
    ndssnes controllerwii u pro contr
    7 Posts 2 Posters 2.3k Views
      mUtt3n
      Hi,
      Which settings do I have to use to make sure my controller will work with NDS-games?
      Actually, I can press the A-button but that's it...
      It works with all other systems and games.
      Thanks!
      • jonnykeshJ
        jonnykesh @mUtt3n
        @mutt3n Which emulator are you using for NDS? DraStic or lr-desmume?
          mUtt3n @jonnykesh
          @jonnykesh I found the problem.....I got both of them installed....I removed DraStic and it works!
          But it's very slow...can I solve this? I'm playing Mario Kart and it's sooooooooooooo sloooooooooooooow :p
            mUtt3n @mUtt3n
            I tried with DraStic but the controllers (SNES Controller & WiiU Pro) won't work with this emulator, any suggestions?
            • jonnykeshJ
              jonnykesh @mUtt3n
              You need to provide more information like what Pi are you using etc. Drastic runs much much much better than lr-desmume.
              Having one emulator installed would not have any effect on the performance of another. the 2 programs do not interact.
              If you are using a Pi3 use DraStic. Hook up a keyboard and during a game hit M to get to the configuration menu. Map controls there.
              I play Mario Kart, Super Mario 64 and lots of others using DraStic and they all run full speed.
                mUtt3n @jonnykesh
                @jonnykesh I didn't know I needed to configure the controls in game, now it's working fine! Many thanks for you help!
                • jonnykeshJ
                  jonnykesh @mUtt3n
                  @mutt3n No problem. Enjoy.
