    Player Index Selector Script
    player indexruncommandswap players
    3 Posts 2 Posters 802 Views
    • H
      hoover40
      My current setup has an x-arcade dual joystick and two controllers plugged into my pi. Sometimes I want to use the controllers and sometimes I want to us the x-arcade dual joystick. I want it to be easy and intuitive to switch the player index for the controllers. I think the easiest way to do this would be in the runcommand-onstart.sh script. I'd like to try to write it myself, but I'm not too sure where to start. This is what I think the simplest version of the script would need to do:
      print "press a button on player 1 control"
      listen for next input on all usb ports
      save needed info from response
      print "press a button on player 2 control"
      write info to appropriate config file
      In the googling I've done I think I can figure out how to do most of these steps, but I'm lost as to how I should do the listen for input on all usb ports step. Can anyone point me in the right direction?
      • H
        hoover40
        Is this way harder than I'm thinking it will be?
          meleu @hoover40
          @hoover40 have you tried the RetroPie-joystick-selection tool?
          It has not the exactly same flow as you described, but you can achieve what you want.
          Link on my signature.
