    Store ALL configs (ES, retroarch, retropie, etc) to external drive and mount it as home directory
    configurationexternal driveconfig fileusb roms
    2 Posts 2 Posters 649 Views
    • F
      feel
      Hi,
      I could not find a similar topic, so I have decided to create a new one.
      I would like to have the possibility to store all my configs (emulationstation and retroarch, etc) and my roms in an external drive, so that I can re-image the SD card with a new Retropie image and having all my data still retained.
      By generalizing the wiki page https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive
      I was able to come up with a solution that achieves that by simply mounting the entire /home/pi directory towards my USB drive. Every single config directory in my home (i.e. /home/pi/.emulationstation and /home/pi/.config/retroarch) is no longer a symlink to /opt/retropie/configs/all/... but instead is a copy so that the configs are actually stored in the external drive.
      The unique inconvenient came up when I had to configure the input controller from ES. The key mapping gets stored automagically by ES to retroarch too, but ES stored the config into /opt/retropie/configs/retroarch/... instead of looking to the user home directory first (~/.config/retroarch). Generally, all applications in Linux give priority to user defined config before taking a look at system config. I believe this would be beneficial for Retropie too as it would allow to make a clear separation of data simplifying life for the final user.
      Do you also consider this an important feature that should be part for future Retropie releases?
      Thank you
      • sunwindS
        sunwind
        What was the solution? I'm trying to mount all my configs and roms and everything on an external usb so the 'OS' just runs from the card and nothing else.
