    K400 PLUS BLUETOOTH PROBLEMS
    connected but
    4 Posts 2 Posters 616 Views
      Daveb3650
      Ive got a Logitech 400 PLUS bluetooth keyboard that is giving me grief. I have paired it fine, it is recognised but when I try to use it nothing happens. I got it for using the Amiga and C64 emulators. I paired my PS4 controller and had to config all the buttons........ Do I have to do this with the key board or am I missing something simple. I've gone through reams of info but not found anything that relates to this.
      Thank You
        mitu Global Moderator @Daveb3650
        @daveb3650 I think you need to configure your keyboard as a controller to be functional in games. Even if it's plug-an-play for EmulationStation, it still needs to be recognized as a controller in games/emulators.
        Just press a key on the keyboard in the Input Configuration dialog and configure the buttons with your keys, then try again to start a game.
          Daveb3650 @mitu
          @mitu Nope....it doesn't register anything........... it paired and is recognised as a keyboard,,,,,then i went to configure it a,d when it says "press a key"....nothing happens
            Daveb3650
            it was me......god i'm thick........................
