    No sound in ES after doing update and theme installs
    speakersno sound issueupdate
    20 Posts 4 Posters 2.7k Views
    • N
      normanmsu96
      Updated all installed packages but chose not to update OS kernel due to some issues I've seen and then all was well but somewhere in the process while installing themes, I lost sound in my video snaps! My only sound source is external speakers, cpu type, input is 3.5mm jack and no additional speakers. Sound is still good within roms. I feel certain either the update or a theme install caused the change/issue I'm having. Any ideas would be much appreciated. I've tried setting to 3.5mm again and also local and speaker is set in ES.
      amixer
      Simple mixer control 'PCM', 0
      Capabilities: pvolume pvolume-joined pswitch pswitch- joined
      Playback channels: Mono
      Limits: Playback - 10239 - 400
      Mono: Playback -300 [93%] [-3.00dB] [on]
      • RedBatmanR
        RedBatman
        So then your on 2.6.5 ES?
        • N
          normanmsu96
          I'm not real sure, but I was using latest retropie 4.2 and then did the update all installed packages.
            pjft
            Are you using VLC or OMX player in ES? Do you have "use OMX player" enabled in the other options menu? Does it make a difference?
            Maybe some update to the video player/library is causing that? Or something with the OS update?
            N 1 Reply Last reply Reply Quote 1
            • N
              normanmsu96 @pjft
              @pjft I believe OMX player is the setting, but I will double check that
              • HexH
                Hex
                @normanmsu96 Can you post your settings config file
                N 2 Replies Last reply Reply Quote 1
                • N
                  normanmsu96 @Hex
                  @hex Yes sir, I will when I get home. Thanks for the read and feedback !
                  • HexH
                    Hex
                    Also post the output of this command
                    aplay -l
                      pjft
                      One thing you can try, if you're using OMX Player, is to run OMX player on the command line to play ones of the videos that don't have sound, and see if it does play with sound.
                      Just to confirm, you're getting the other ES navigation sound?
                      • N
                        normanmsu96 @Hex
                        @hex Certainly will
                        • N
                          normanmsu96
                          @pjft What is that command?
                          • N
                            normanmsu96 @Hex
                            @hex You mean type exactly that or sudo aplay -1 ....Sorry unfamiliar w key in commands
                            • HexH
                              Hex
                              just the command. no need of sudo
                                pjft @normanmsu96
                                @normanmsu96 in the command line, should be
                                omxplayer <video filename>
                                • N
                                  normanmsu96 @Hex
                                  @hex # For more options and information see
                                  http://rpf.io/configtxtreadme
                                  Some settings may impact device functionality. See link above for details
                                  uncomment if you get no picture on HDMI for a default "safe" mode
                                  #hdmi_safe=1
                                  uncomment this if your display has a black border of unused pixels visible
                                  and your display can output without overscan
                                  #disable_overscan=1
                                  uncomment the following to adjust overscan. Use positive numbers if console
                                  goes off screen, and negative if there is too much border
                                  #overscan_left=16
                                  #overscan_right=16
                                  #overscan_top=16
                                  #overscan_bottom=16
                                  uncomment to force a console size. By default it will be display's size minus
                                  overscan.
                                  #framebuffer_width=1280
                                  #framebuffer_height=720
                                  uncomment if hdmi display is not detected and composite is being output
                                  #hdmi_force_hotplug=1
                                  uncomment to force a specific HDMI mode (this will force VGA)
                                  #hdmi_group=1
                                  #hdmi_mode=1
                                  uncomment to force a HDMI mode rather than DVI. This can make audio work in
                                  DMT (computer monitor) modes
                                  #hdmi_drive=2
                                  uncomment to increase signal to HDMI, if you have interference, blanking, or
                                  no display
                                  #config_hdmi_boost=4
                                  uncomment for composite PAL
                                  #sdtv_mode=2
                                  gpu_mem=400
                                  arm_freq=1350
                                  over_voltage=5
                                  sdram_freq=500
                                  core_freq=500
                                  gpu_freq=400
                                  Uncomment some or all of these to enable the optional hardware interfaces
                                  #dtparam=i2c_arm=on
                                  #dtparam=i2s=on
                                  #dtparam=spi=on
                                  Uncomment this to enable the lirc-rpi module
                                  #dtoverlay=lirc-rpi
                                  Additional overlays and parameters are documented /boot/overlays/README
                                  Enable audio (loads snd_bcm2835)
                                  dtparam=audio=on
                                  gpu_mem_256=128
                                  gpu_mem_512=256
                                  gpu_mem_1024=256
                                  overscan_scale=1
                                  display_rotate=1
                                  • N
                                    normanmsu96
                                    After all that I discovered I need sound setting in ES as PCM instead of SPEAKER. Back working !
                                    • HexH
                                      Hex
                                      So its working now?
                                      BTW I was asking you for the es_settings.conf file. Also you should quote the Code you want to insert using this symbol ``` and it will look like this
                                      Hello
                                        pjft @normanmsu96
                                        @normanmsu96 huh. Did you set it to speaker at any point per chance? The default is PCM so I'm surprised that that was changed for you.
                                        Glad you're sorted though.
                                        • N
                                          normanmsu96 @pjft
                                          @pjft I guess I had changed that but I don't recall doing it
                                          • N
                                            normanmsu96
                                            @hex Yes working now, sorry for the confusion
