    Help pls.. in menu MAME2010 pi3
    mame2010retro pie
    6 Posts 2 Posters 1.1k Views
      teaw
      Hello everyon
      I can not access this menu. And find no enter button in MAME2010.
      but MAME2003 is OK.
      how can i restore defaults (MAME2010)
      Thank you very much
        mitu Global Moderator @teaw
        @teaw Your image is not showing correctly so we cannot see what you're talking about. If you wish to switch to another MAME emulator for a ROM/folder, then use the RunCommand launch when starting the ROM to change the emulator - https://retropie.org.uk/docs/Runcommand/#runcommand-launch-menu.
        Also, it would be helpful to know your system more - read https://retropie.org.uk/forum/topic/3/read-this-first and answer the questions there.
          teaw
          thanks. @mitu
          I think this would be the case.
          link text
          But,I can not find MAME2010 default.cfg :(
            @teaw In the topic you link, the problem seems to be about mame2003, but your problem seems to be about opening the mame2010 menu - am I correct ?
            Do you have a keyboard connected ? Can you open the menu for the emulator BUT you cannot chooose the Enter key ? I'm sure I follow completely your problem.
            Please take a moment to give some answers as requested in https://retropie.org.uk/forum/topic/3/read-this-first.
              teaw @mitu
              Yes, I Can open the menu in MAME2010 emulator press TAB/L2 . But I cannot chooose Enter to menu inside
              My keyboard & gamepad all key No button to Enter.
              Thank you for answer
                @teaw I don't have a keyboard to test, but do you have a specific reason for using Mame2010 instead of Mame2003 or AdvMame ?
