    Small little Fan on Raspberry Pi?
    cooling fanfangpio
    11 Posts 4 Posters 2.7k Views
    • DarkSide1305D
      DarkSide1305
      Hello. I wanted to cool my Raspberry Pi with RetroPi. So, i found this small little Fan i could glue into the Housing, but i would like to know if any of the GPIO Header Pins would work.
      Picture: https://abload.de/img/1510311763832-1824900ivu28.jpg
      • jonnykeshJ
        jonnykesh @DarkSide1305
        @darkside1305 I can't see the specs of the fan but if it runs on 5V it should work OK. Connect the red wire to a 5V or 3.3V pin and the black to ground. The white wire is probably for a sensor.
        • DarkSide1305D
          DarkSide1305
          It says 0.18A and 12VDC. And, how would i connect them? Taking off the White Thing, and then?
          • jonnykeshJ
            @darkside1305 It might run off the 5V pin but very slowly.
            Yes, you would need to remove the existing connecter and solder the wires directly to the pins or buy some female ended jumper wires and splice them.
            • DarkSide1305D
              DarkSide1305
              Well, i tried holding it against it, didnt worked.
              • jonnykeshJ
                @darkside1305 Just buy a 5V fan with connectors already attached. There is one on Amazon UK for £1.10.
                • DarkSide1305D
                  DarkSide1305
                  Ok, i got it to work. We at my Workplace can solder, so im going to do that
                  • Z
                    zerojay
                    It's quite amazing how well a small little 5v fan for $2 works in cooling everything.
                    • caver01C
                      caver01 @zerojay
                      @zerojay Are you using one? I have only a heatsink, but I will need one for my next project I expect. I know there are other threads on this topic, but if you have one you like I would take note. I have read reviews of some that say they move very little air, or they are super noisy.
                      • Z
                        zerojay
                        The one I have is a little noisy but I almost never notice it over the volume of whatever I'm playing. I have a clear acrylic case with heatsink already installed and the fan on the top part of the case. It's small and doesn't move much air but the temps have dropped considerably.
                        • caver01C
                          caver01 @zerojay
                          @zerojay Thanks. Good to know.
