    Issues on Restart ES/Shutdown/Restart System - Quit Menu
    shutdown scriptrestartissuequitmenu
    2 Posts 1 Posters 880 Views
    • fredcobainF
      fredcobain
      After rebuild EmulationStation, the Quit menu actions are not working anymore.
      The files /tmp/es-restart, /tmp/es-sysrestart and /tmp/es-shutdown are properly created when I choose the corresponding actions.
      The main problem is: the files still there and the system only quits emulationstation (back to terminal) no matter if I choose restart or shutdown... (doesn't working properly)
      The /tmp/es-xxxxxx files still there after all.
      It seems emulationstation cannot delete them and also cannot perform the expected action.
      The script /opt/retropie/supplementary/emulationstation/emulationstation.sh seems not to be working.
      Any ideas to solve it ?
      Thanks in advance
      • fredcobainF
        fredcobain
        Solution:
        Copied emulationstation from /usr/bin to /usr/local/bin and things worked as normal.
