    Changing universal controller config/not enough buttons
    usb gamepadcontrollermap
    5 Posts 2 Posters 7.6k Views
      kruuth
      Hi I am using Logitech F310 gamepads and when I go to config I set everything up but I don't have enough buttons to set the last command. Is there a way to bypass this somehow? Also, how do I change the universal configuration for gamepads in emulation? Right now the buttons are all mapped wrong despite working in EmulationStaion.
      danielmewhouseD 1 Reply Last reply Reply Quote 0
      • danielmewhouseD
        danielmewhouse @kruuth
        @kruuth If this issue occurs on the Emulationstation input config option, you could bypass the last command simply holding any configured button.
        It's no use!!! Take this!!!
          kruuth @danielmewhouse
          @danielmewhouse
          Awesome. Thank you. What about changing the default mapping for all the systems at once? Like if I press button 1 it goes back to EmulationStation. I'd like to remap it.
          • danielmewhouseD
            @kruuth did you opened retroarch on any system and saved a per system config? If so, delete any custom config and try again. If it doesn't work, try going to retropie menu, option retroarch, configure your input and this could solve your issue.
              kruuth
              What is the setting where you go back/exit called? If I push 1 on the logitech pad I exit emulation, which is the B button in nes games.
