    Better Hardware for Raspberry Pi 4
    hardwareretropieraspberry pi 4
    11 Posts 4 Posters 2.6k Views
    • jwbmonkJ
      jwbmonk
      Do you mean pi 3? It already plays psx and n64.....
      • Bl3ndB
        Bl3nd
        I'm not 100% sure but I just want it to be a little beefier
        • markyh444M
          markyh444 @Bl3nd
          @bl3nd There is no Pi4 yet mate, and there is no way you can boost the current board to play PS2 games as they're not expandable.
          I'd suggest waiting about til they release a newer board (not likely to be soon), or run emulators for these other consoles on a PC with a decent graphics card in.
          Retropie in a PSX - Pi3
          danielmewhouseD 1 Reply Last reply Reply Quote 0
          • Bl3ndB
            Bl3nd
            Ok, I got it last Christmas and didn't really pay attention to what version I got. Thanks for your help!
            • danielmewhouseD
              danielmewhouse @markyh444
              @markyh444 I think odroid could be a work around solution for our friend. It has more horsepower under the hood than RPi3.
              It's no use!!! Take this!!!
              • Bl3ndB
                Bl3nd
                Is it the same size?
                • danielmewhouseD
                  danielmewhouse @Bl3nd
                  @bl3nd just a little bit bigger. Here you can see a comparation between odroid and RPi3:
                  https://www.slant.co/versus/5727/15521/~odroid-xu4_vs_raspberry-pi-3-model-b
                  Bl3ndB 1 Reply Last reply Reply Quote 0
                  • Bl3ndB
                    Bl3nd @danielmewhouse
                    @danielmewhouse Would it be possible to just move the micro sd or something simple like that?
                    • danielmewhouseD
                      @bl3nd sorry man, this question I can't answer, but I think it has an internal storage disk and a sdcard slot. But you need to get a specific image for odroid, 'cause there's some hardware differences.
                      • Bl3ndB
                        Bl3nd
                        Ok, Thanks for your help!
