Slash Screen Help!
The text has been removed now, thank you. Do you have any idea why my Splash screen takes so long to start tho ?
@dirtydond because the Pi has to boot and initialise services and programs before it can play the splash video.
No video player running = no video. -
Makes sense yeah, thanks for the Help !
@dirtydond the Pi will boot more quickly if you turn off
wait for network on boot
This can be done by runningsudo raspi-config
then chooseadvanced options
boot options
@jonnykesh When i go into the advanced settings there is no option to disable this feature. I will look around for this in some other settings.
It's actually in "boot options" of raspi-config.
Yes, i found this. Thanks for the reply tho !
@jonnykesh If you disable this option
, will it eventually connect to the network? -
@hiulit Yes it will. It just won't halt the rest of the boot process waiting for a network connection.
@jonnykesh Nice! I'll try it then, thanks!
