PI2SCART problem with shell script for CRT TV
Hello,
I have a problem with the shell script of Frank Skilton.
I have installed it in /root/video like the unzipped file but I can't launch the script with RetroPie only with PuTTy.
So I can't calibre my CRT TV... -
@retrocrtgames I don't know why this is a PI2Scart problem, but..
If you'd like to run the script and output to the TV, just exit EmulationStation (F4 or just use the menu to quit) and you'll be dropped to a command prompt, from where you could execute the command/run the script, just like you would in a SSH session. -
Sorry, it's a mistake.
Thanks. -
New problem when I input Q.
The terminal say : line 77 : fbv unfound command.
How can I solve this problem ?
it's a package to add ? -
@retrocrtgames I'm not sure if there's a package for fbv in Raspbian, but you can download and compile it from https://github.com/godspeed1989/fbv.
EDIT: looking at the script, it seems you can replace
fbv
with eitherfbi
orfim
, for which there are packages already built in Raspbian.
Try installing either of them (apt-get install fim
for instance) and then edit the script and replace (on line 77)fbv
withfim
I have replace fbv with fbi and now it works !
Thanks !
@RetroCrtGames Can you help me how to enable these commands? Sudo chmod + x set_video.sh
Sudo bash ./set_video.sh I am reaching the / root / video folder and I can't turn them on ๐ ๐
