    Monitor going black & saying power save all of a sudden?
    monitorscreencablehdmi to dvipower save
    4 Posts 3 Posters 1.5k Views
      Michael40475
      I am using a Raspberry PI 3 and was doing several of things on my monitor, when all of a sudden the monitor went black. It would say power save mode or something like that. Well, I checked the hdmi to dvi cable, when I move the cable the screen will go back to what I was doing, then a couple seconds later it would go black, or say power save? Do I need to replace my HDMI to DVI cable? Could that be the problem? Or is something wrong with my Raspberry PI? I think replacing the cable will solve my problems. Please help me with this matter, I'm a HUGE NOOB at this.
      • markyh444M
        markyh444 @Michael40475
        @michael40475 I'd try another cable because if it comes back on when you wiggle it, it sounds like it's dodgy. I'd try just a bog standard HDMI if you can.
        Retropie in a PSX - Pi3
        • matchamanM
          matchaman
          I'm pretty sure it has to do with your cable. Power saving comes up either if you have set a limited idle time in your TV's menu (without any input from you - not the signal) or it comes up if there is no signal coming in order to conserve energy from its backlight.
            Michael40475 @matchaman
            @matchaman I replaced the hdmi to dvi cable and it works great now! Thank you so much everyone!
