    Need help with Start + Select hotkey to exit game. Please Help!!
    helpgame genie codehotkeydisablestart + select
    6 Posts 4 Posters 2.6k Views
    • BennyBoiiB
      BennyBoii
      Hi, today I wanted to use some game genie codes on super mario world. I found one that was definitely one that I MUST use, it requires clicking Start + Select to skip the level, but since clicking start + select exits the game, I won't be able to use the amazing code! I have beat the game before legit so don't call me a cheater :) I'm just asking if there's a way to easily disable that one hotkey? To Disable the hotkey where it exits the game you're playing if you press Start and select at the same time? Thanks!! I am using the Raspberry Pi 3, connected with my own wifi.
      HyruleslinkH 1 Reply Last reply Reply Quote 0
      • HyruleslinkH
        Hyruleslink @BennyBoii
        @ben-almonte You could set your hotkey to a different button. Just reconfigure your controls for that controller in Emulationstation.
        • BennyBoiiB
          BennyBoii
          This post is deleted!
          • BennyBoiiB
            BennyBoii
            @hyruleslink Can you please help me by giving me a step-by-step on how to do it? Thanks!
            BobHarrisB 1 Reply Last reply Reply Quote 0
            • Z
              zerojay
              Alternatively, change the game genie code to trigger with a different set of buttons.
              • BobHarrisB
                BobHarris @BennyBoii
                @ben-almonte Update to retropie 4.3. Reconfigure your controller. The last button to configure is the hotkey, so you can assign that to something other than select.
                Pi 3B , 64 GB Sandisk ultra flashdrive, 19 systems, 872 hand picked classic gaming gems :-) Dual shock 4v2
