    Need help setting my rasberry pi 3 up for playing emulator roms
    tag
    11 Posts 6 Posters 2.1k Views
      RedSlayer
      I download the file from retro pie but it is not in a zipped folder, write it onto my sd card using win32 imager and plug everything up with the correct power cable and hdmi. Nothing loads just a black screen. New to all this and have no idea whats wrong. any help is aprecciated
      caver01C rbakerR 3 Replies Last reply Reply Quote 0
      • caver01C
        caver01 @RedSlayer
        @redslayer I have read some of the comments for win32imager about using compatibility mode in Windows 10, or running it as ADMIN, etc. all related to properly writing the disk image to the SD card.
        Are you able to write any other disk images to the card? Because it sounds like your card is not getting the image written properly. It is hard to proceed until you can setup the SD Card for a first boot.
        • rbakerR
          rbaker @RedSlayer
          @redslayer
          https://retropie.org.uk/docs/First-Installation/
          It is. It's a disk image in a compressed format.
          Will not work with win32 imager unless you unzip it first - I use winrar to unzip.
          • rbakerR
            rbaker @RedSlayer
            @redslayer I think etcher can write the zipped image!
            herb_fargusH 1 Reply Last reply Reply Quote 2
            • herb_fargusH
              herb_fargus administrators @rbaker
              @rbaker I second that. Etcher is a simpler option than win32diskimager
                RedSlayer
                retropie-4.3-rpi2_rpi3.img, type Snes9x Rom. this is this file downloads when I click the link for the raspberry 2/3 no matter how many times i do it. I don't get a compressed file not sure why but that is the issue I have right now
                jonnykeshJ rbakerR 3 Replies Last reply Reply Quote 0
                • jonnykeshJ
                  jonnykesh @RedSlayer
                  @redslayer Try a different browser.
                  • rbakerR
                    rbaker @RedSlayer
                    The file is 611.91MB and is a .gz archive that can be uncompressed with a variety of programs. I just downloaded it. It's there and uncompresses in about 40secs on my i5 to a Disc Image File (.img) that can then be written to the SD card of your choice. Check ad blockers, browser settings, antivirus settings, firewall etc.
                    • rbakerR
                      rbaker @RedSlayer
                      type Snes9x Rom
                      What do you mean by this?
                        Raspbian101
                        you need 7zip or WinRAR. to extract it, be sure to extract the folder to your desktop. then use the sd card formatter to format your micro sd card for the pi. then use the win32imager to install the iso image of retro pie and emulation station.
                        any other questions. feel free to ask!
                          RedSlayer
                          I couldn't figure out the extracting thing for the file but I got it to work with etcher. Thank ya'll for the advise and guidance. I'm completely new to all this and suck with computers
