    Theme help
    themetheme helpimages
    2 Posts 2 Posters 614 Views
    • paffleyP
      paffley
      Hi,
      I'm creating a theme at the moment and was wondering if its possible to apply a random image selected from a folder for each individual system.
      Example:
      on system select: master system - image1
      on system select: megadrive - image 2
      and so on.....
      • E
        EctoOne
        Do you just want a different image for each system or do you want a random image for a single system?
        Anyway, as far as I know there is no way to randomize any value that can be used as path/filename to images.
        Having a different image for each system can be done by either using the system folder theme.xml or by using variables as paths/filename.
        If you need/want to have different colors for each system as well, you have to use the old system folder theme.xml otherwise I would suggest to use variables.
