    low power warning with mausberry.
    low powermausberrypower problem
    3 Posts 2 Posters 990 Views
      p33te
      I had been getting the low power warning in the top of the screen so I got one of these from ebay: link along with a 3.5a charging cable which sorted the low power warning but I have just added a mausberry circuit (and a second 3.5a cable) to use as a power switch and now I am getting the low power warning again. Does anyone know anything I can do besides not using the mausberry? Besides the mausberry I also have a fan connected to pins 1 (3.3v) and pin 2 as well as 2 zero delay usb encoders (it's a lack coffee table build).
      Pi Model or other hardware: 3 model B
      Power Supply used: 5V 4A
      RetroPie Version Used : 4.3
      USB Devices connected: USB Wireless Keyboard, 2x zero delay arcade encoders
      Controller used: zero delay arcade encoders
      • retroprogrammerR
        retroprogrammer
        I think your fan is using to much power to quickly, I would take it off and test
        Here is me converting the original Xbox for a case:
        https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
        Check out my GitHub: https://github.com/retro-programmer
        • retroprogrammerR
          retroprogrammer
          Or get the proper raspberry pi power supply
