    PIFBA with usb sony ps2 controller problems.
    1 Posts 1 Posters 689 Views
      corruptgrim
      I've been banging my head on the wall for days now trying to solve an issue I have with PIFBA controls.
      I use a sony ps2 controller with a usb adapter and have also tried with a ps4 controller. When ever I try to play pifba the controls are all over the place only the dpad and start and select work correctly.
      All my other emulators are fine and the retro guide works perfect!, even the other fba emulators work fine other than performance issues.
      I've tested my inputs using cd /dev/input jtest js0 and all is fine and I've tried editing the fbax2.cfg over and over again!.
      Some times I get close to having a good config but 1 button change makes them all change again.
      Has anyone had the same issue or have any suggestions on fixing this?
