    help setting vertical games with bezel and crt pi
    screen resolutishaderscrt-pi-vertical
    12 Posts 3 Posters 3.2k Views
      juice
      can anyone help me, i have set up shaders and bezels for arcade games and the horizontal games look ok with crt pi shader. but when i setup vertical games with bezel and crt pi vertical , the screen look terrible very blurry with trailers off the bullets etc on 1942 ,gun smoke. can anyone explain what settings i should have to get best picture that is close to a arcade. i am using 1080p tv. i am using Mr H Arias Bezel Pack and have scaled the game screen to fit (i think that the problem,because i did not want boarders)
      thanks for your time
      pi3
      retropie 4.3.7
      latest build
      mamelr-2003
      mamelr-2010
      lr-fba alpha
        dankcushions Global Moderator @juice
        @juice https://retropie.org.uk/forum/topic/4046/crt-pi-shader-users-reduce-scaling-artifacts-with-these-configs-in-lr-mame2003-lr-fbalpha-lr-nestopia-and-more-to-come
          juice
          thanks for the reply i check it out,this is what i am looking for .
            juice
            hello mate, i having problems with screen size after i dropped file in cfg. the picture look good, but it is to big for screen . it must be cutting off a quarter of the top and bottom,and is to wide(no boarders to put bezel) what can i do to change this. thanks
              juice
              can anyone help me with this issue,thanks
              chipsnblipC 1 Reply Last reply Reply Quote 0
              • chipsnblipC
                chipsnblip @juice
                This post is deleted!
                  @juice what screen are you using and what cfg pack?
                    juice
                    i am using a 49 lg 1080p tv ,pi running at 1080p . and using crt-pi_fbalpha_configs_1920x1080 or crt-pi_mame2003_configs_1920x1080 depending with emulator i am using. i trying 1942 rom out using mame 2003. screen looks full width but to length cut of top and bottom. so i need to shrink the the sides down and the height to fit the screen , let alone the bezel.
                    this is my cfg i know it wrong but fits right with bezel but bad picture.
                    thanks (ps i using this directory \RETROPIE\configs\all\retroarch\config\FB Alpha)
                    ui_companion_start_on_boot = "true"
                    input_remap_binds_enable = "true"
                    netplay_public_announce = "true"
                    netplay_allow_slaves = "true"
                    netplay_client_swap_input = "true"
                    input_descriptor_label_show = "true"
                    load_dummy_on_core_shutdown = "true"
                    builtin_imageviewer_enable = "true"
                    framecount_show = "true"
                    ui_menubar_enable = "true"
                    suspend_screensaver_enable = "true"
                    audio_sync = "true"
                    video_shader_enable = "true"
                    video_allow_rotate = "true"
                    video_windowed_fullscreen = "true"
                    video_crop_overscan = "true"
                    video_force_aspect = "true"
                    auto_screenshot_filename = "true"
                    video_vsync = "true"
                    pause_nonactive = "true"
                    keyboard_gamepad_enable = "true"
                    core_set_supports_no_game_enable = "true"
                    audio_enable = "true"
                    video_font_enable = "true"
                    core_updater_auto_extract_archive = "true"
                    threaded_data_runloop_enable = "true"
                    menu_throttle_framerate = "true"
                    menu_linear_filter = "true"
                    menu_horizontal_animation = "true"
                    dpi_override_enable = "true"
                    menu_pause_libretro = "true"
                    menu_mouse_enable = "true"
                    menu_timedate_enable = "true"
                    menu_battery_level_enable = "true"
                    menu_core_enable = "true"
                    quick_menu_show_take_screenshot = "true"
                    quick_menu_show_save_load_state = "true"
                    quick_menu_show_undo_save_load_state = "true"
                    quick_menu_show_add_to_favorites = "true"
                    quick_menu_show_options = "true"
                    quick_menu_show_controls = "true"
                    quick_menu_show_cheats = "true"
                    quick_menu_show_shaders = "true"
                    quick_menu_show_save_core_overrides = "true"
                    quick_menu_show_save_game_overrides = "true"
                    quick_menu_show_information = "true"
                    materialui_icons_enable = "true"
                    xmb_show_settings = "true"
                    xmb_show_favorites = "true"
                    menu_show_load_core = "true"
                    menu_show_load_content = "true"
                    menu_show_configurations = "true"
                    menu_show_help = "true"
                    menu_show_quit_retroarch = "true"
                    menu_show_reboot = "true"
                    xmb_show_netplay = "true"
                    menu_navigation_wraparound_enable = "true"
                    menu_navigation_browser_filter_supported_extensions_enable = "true"
                    input_overlay_enable = "true"
                    input_overlay_enable_autopreferred = "true"
                    input_overlay_hide_in_menu = "true"
                    keymapper_enable = "true"
                    netplay_nat_traversal = "true"
                    history_list_enable = "true"
                    playlist_entry_remove = "true"
                    playlist_entry_rename = "true"
                    game_specific_options = "true"
                    auto_overrides_enable = "true"
                    auto_shaders_enable = "true"
                    audio_rate_control = "true"
                    netplay_check_frames = "600"
                    input_bind_timeout = "5"
                    input_turbo_period = "6"
                    input_duty_cycle = "3"
                    audio_latency = "64"
                    libretro_log_level = "1"
                    keyboard_gamepad_mapping_type = "1"
                    input_poll_type_behavior = "2"
                    network_cmd_port = "55355"
                    network_remote_base_port = "55400"
                    dpi_override_value = "200"
                    menu_thumbnails = "3"
                    xmb_alpha_factor = "75"
                    xmb_scale_factor = "100"
                    xmb_menu_color_theme = "4"
                    menu_shader_pipeline = "1"
                    audio_out_rate = "48000"
                    custom_viewport_width = "345"
                    custom_viewport_height = "454"
                    custom_viewport_x = "252"
                    custom_viewport_y = "13"
                    content_history_size = "100"
                    video_max_swapchain_images = "3"
                    aspect_ratio_index = "22"
                    netplay_ip_port = "55435"
                    video_aspect_ratio = "-1.000000"
                    video_scale = "3.000000"
                    video_refresh_rate = "60.000000"
                    audio_max_timing_skew = "0.050000"
                    input_overlay_opacity = "0.700000"
                    input_overlay_scale = "1.000000"
                    menu_wallpaper_opacity = "0.300000"
                    menu_framebuffer_opacity = "0.900000"
                    menu_footer_opacity = "1.000000"
                    menu_header_opacity = "1.000000"
                    video_message_pos_x = "0.050000"
                    video_message_pos_y = "0.050000"
                    slowmotion_ratio = "3.000000"
                    video_msg_bgcolor_opacity = "1.000000"
                    video_driver = "gl"
                    record_driver = "null"
                    camera_driver = "null"
                    wifi_driver = "null"
                    location_driver = "null"
                    audio_driver = "alsathread"
                    audio_resampler = "sinc"
                    input_driver = "udev"
                    core_updater_buildbot_url = "http://buildbot.libretro.com/nightly/linux/armhf/latest/"
                    core_updater_buildbot_assets_url = "http://buildbot.libretro.com/assets/"
                    libretro_directory = "~/.config/retroarch/cores"
                    libretro_info_path = "~/.config/retroarch/cores"
                    video_shader = "~/.config/retroarch/shaders/retroarch.glslp"
                    content_database_path = "~/.config/retroarch/database/rdb"
                    cheat_database_path = "~/.config/retroarch/cheats"
                    input_overlay = "~/.config/retroarch/overlay/MAME-Vertical.cfg"
                    cursor_directory = "~/.config/retroarch/database/cursors"
                    screenshot_directory = "~/.config/retroarch/screenshots"
                    video_shader_dir = "~/.config/retroarch/shaders"
                    core_assets_directory = "~/.config/retroarch/downloads"
                    assets_directory = "~/.config/retroarch/assets"
                    thumbnails_directory = "~/.config/retroarch/thumbnails"
                    playlist_directory = "~/.config/retroarch/playlists"
                    joypad_autoconfig_dir = "~/.config/retroarch/autoconfig"
                    rgui_config_directory = "~/.config/retroarch/config"
                    overlay_directory = "~/.config/retroarch/overlay"
                    input_libretro_device_p1 = "1"
                    input_player2_joypad_index = "1"
                    input_libretro_device_p2 = "1"
                    input_player3_joypad_index = "2"
                    input_libretro_device_p3 = "1"
                    input_player4_joypad_index = "3"
                    input_libretro_device_p4 = "1"
                    input_player5_joypad_index = "4"
                    input_libretro_device_p5 = "1"
                    input_player6_joypad_index = "5"
                    input_libretro_device_p6 = "1"
                    input_player7_joypad_index = "6"
                    input_libretro_device_p7 = "1"
                    input_player8_joypad_index = "7"
                    input_libretro_device_p8 = "1"
                    input_player9_joypad_index = "8"
                    input_libretro_device_p9 = "1"
                    input_player10_joypad_index = "9"
                    input_libretro_device_p10 = "1"
                    input_player11_joypad_index = "10"
                    input_libretro_device_p11 = "1"
                    input_player12_joypad_index = "11"
                    input_libretro_device_p12 = "1"
                    input_player13_joypad_index = "12"
                    input_libretro_device_p13 = "1"
                    input_player14_joypad_index = "13"
                    input_libretro_device_p14 = "1"
                    input_player15_joypad_index = "14"
                    input_libretro_device_p15 = "1"
                    input_player16_joypad_index = "15"
                    input_libretro_device_p16 = "1"
                      @juice that is a non-default .cfg with lots of settings that will affect picture/resolution so i don't know what to suggest, really. the cfgs in that thread are for default retropie.
                        juice
                          juice
                          @dankcushions is there a way to delete all the cfg and start again, or do i need to make a fresh build. i would like to use you files as it is the way forward
                            @juice said in help setting vertical games with bezel and crt pi:
                            where is the config file you posted above from?
