    Raspberry PI 3 Ethernet problem
    raspberry pi 3ethernetnot working
    6 Posts 2 Posters 2.5k Views
    • N
      Nextria
      Hello,
      I have a problem with my Retropie/Raspberry. I flashed the SD card with the latest version.
      Only i can not get the ethernet to work,
      It gives me a ipadress of 169.254.9.111, so it can not find my DHCP server i think.
      I tried giving it a static IP adres
      i changed /etc/network/interfaces to iface eth0 inet static.
      and added the following to /etc/dhcpcd.conf
      interface eth0
      static ip_address=192.168.1.128/150
      static routers=192.168.1.1
      static domain_name_servers=192.168.1.1
      but it does not change anything. Does anyone have any idea ?
      • markyh444M
        markyh444 @Nextria
        @nextria 192.168.1.128/150 is not a valid IP. I am assuming standard private IP addressing and your subnet is probably going to be 255.255.255.0 so your IP should be 192.168.1.128/24
        As to why it's not giving you a DHCP, I have no idea. Have you tried another cable and port on your router?
        Retropie in a PSX - Pi3
        • N
          Nextria
          @markyh444 hey, i tried that ipadres too, but it does not work either.
          I redownloaded the img, and flashed it to the sdcard but no luck.
          Also tried other cable and port, could it be my pi's ethernet is broken ?
          • markyh444M
            markyh444 @Nextria
            @nextria maybe, have you tried configuring the WiFi? Do your other devices connect to the router fine and get assigned a DHCP address?
            • N
              Nextria
              @markyh444 yes wifi works without any problem I also tried it now with rabian lite and is also not working.
              • markyh444M
                markyh444 @Nextria
                @nextria I'd say dodgy LAN port or cable then.
