Navigation
    • Search
    lag with 8Bitdo SF30PRo
    Help and Support
    8bitdo lags bluetooth sf30pro
    5
    6
    1802
    • TitQuentin
      TitQuentin last edited by
      Hello everyone!
      I just received my 8bitdo SF30Pro controller (http://www.8bitdo.com/sn30pro-sf30pro/)
      I updated the firmware of the controller in v1.10 and RetroPie too
      However I have lags problem in the RetroPie menu and in all games
      Is there a solution to this problem?
      Thank you in advance.
      I have Pi3 Model B with 3A power
      8bitdo controller connect in Bluetooth
      TitQuentin
      markyh444 meats 2 Replies Last reply Reply Quote 0
      • markyh444
        markyh444 @TitQuentin last edited by
        @titquentin I recall somebody else having a similar issue awhile back and it was due to the controller having low charge. Have you tried recharging it fully?
        TitQuentin 1 Reply Last reply Reply Quote 0
        • saccublenda
          saccublenda last edited by
          I had a similar problem when using the internal Bluetooth controller. Using an external Bluetooth dongle greatly improved the situation.
          • TitQuentin
            TitQuentin @markyh444 last edited by
            @markyh444 said in lag with 8Bitdo SF30PRo:
            Hi @markyh444 my controller it's fully charged ! And I have lags ! :(
            @saccublenda said in lag with 8Bitdo SF30PRo:
            @saccublenda I can't try this solution because I d'ont have Bluetooth dongle.
            But my another 8bitdo controler work very fine !
            Thx for reply guys !
            • BobHarris
              BobHarris last edited by
              Have you tried using it on your desktop pc/laptop? Is the same amount of lag present?
              Two reviewers on youtube mentioned the input lag..they expected 8bitdo to fix it with a firmware update.
              • meats
                meats @TitQuentin last edited by
                @titquentin
                did you disable wifi?
                what mode did you pair it with (Switch, Android, macOS or Windows)?
