installing retropie to sd card using hp chromebook
Hi so i have a raspberry pi and would like to know if i can install retropie on my sd card using my hp chromebook. All i see is people using windows to unzip files and format sd cards. If i can use the chromebook please tell me what i need to download.
Thanks!!! -
It seems that you should be able to use the linux way by being in developer mode, opening crosh, and typing
shell
You then will have a bash shell, with the dd command.
Careful to use the correct device as target for dd.I also see that the chromebook recovery utility can be used too - see here : https://www.reddit.com/r/chromeos/comments/7d02im/using_a_chromebook_to_install_an_iso_to_a_usb/
