    Fix for overlapping Nes-Mini, Snes-Mini Theme, The 1366x768 Issue
    snes-mini fixnes-mini fixscraper fixsnes-mini themenes-mini theme
    2 Posts 2 Posters 854 Views
      diqits
      Finally i found the reason why the nes-mini, snes-mini Theme did overlap on my TV-Screen. Also the Scraper did not work properly. Now it does:
      I have a 1366x768 TV, but the Rasperry Pi was not correctly adjusted to it. In Raspi-config you can only change the Resolution to 1280x1024, so you need to go in your /boot/config.txt and change it manually.
      activate hdmi_group=2 this changes the HDMI Mode to DMT, only DMT has the Resolution 1366x768
      hdmi_mode=81 this changes the Resolution to 1366x768 & 60 Hz
      Save config.txt and restart your Pi and you're good to go.
      I put this out for People who had the same issue and didn't find a solution.
      You're Welcome
      • akafoxA
        akafox
        My pi plugged into a 720x400 CRT TV so it is a fixed resolution. Would be nice get it to work though. I like it :D
