    Odyssey/VIdeopac Controller Player 1 doesn't work
    26 Posts 5 Posters 9.4k Views
    • Turk182T
      Turk182
      Hi,
      The player 1 doesn't work on the Videopac/Odyssey emulator.
      Only Player 2 can be controlled.
      Is there any update about this issue ?
      Best regards.
        tigerinatlanta
        HI. Did you ever get an answer for this? This is similar to what I am experiencing. I cant seem to remap where I can play "Left Handed Keyboard" settings/games such as UFO. I can launch the game, but do not experiencing any movement or firing.
        • Turk182T
          Turk182
          Hi,
          I never found a solution, the issue is that the emulator take the player 2 as first player, so you cannot play with only one controller ... My workaround is to use two controllers and then play with controller 2.
          I would like one day, that the emulator's developer fix this issue.
          Hope it will help you.
            tigerinatlanta
            Thanks for the feedback Turk. So what kind of controllers do you use? I am just using a single USB Snes controller.
            Are you able to play UFO?
            Turk182T 1 Reply Last reply Reply Quote 0
            • herb_fargusH
              herb_fargus administrators @Turk182
              @Turk182 an option was just added to the configuration editor to change the index of your controller or you can set it manually through retroarch.cfg so you could set your second controller as controller 1 if that makes sense.
              • Turk182T
                Turk182 @herb_fargus
                @herb_fargus oh thank you I will look at this so, but I have this issue only with Odissey emulator.
                • Turk182T
                  Turk182 @tigerinatlanta
                  @tigerinatlanta I have a Logitech F710 and a PS3 controller.
                    tigerinatlanta
                    @herb_fargus - Hi, Could you explain further how I would do this? So do I have to have a 2nd controller to be able to? I am just trying to do this on the Odyssey2/Videopac as well.
                    • herb_fargusH
                      herb_fargus administrators @tigerinatlanta
                      @tigerinatlanta you'll have to update to the latest setup script if you want to change it through the configuration editor or in the system based retroarch.cfg you'll add a line something like input_player2_joypad_index = "0" above the #include line. but if its an issue fundamentally with the emulator rather than the player order (i.e. only player two works and player one never worked) then it may not really solve anything. may be worth checking settings in the RGUI at that point with controller remapping or something. Likely you'll need to try a few things before you get it sorted.
                        tigerinatlanta
                        Thanks @herb_fargus - Basically most of the O2/Videopac games work out of the box with the default configuration. The windows emulator for O2 has a specifier of Default Left or Right Keys for Stick 1 or 2. A few games such as UFO require the left Key(Stick 2) configuration that wont run by default. Sounds like modifying the retroarch.cfg file in O2 wont really fix the issue as it will impact the games that work the other way.
                          edmaul69
                          So here is the issue with the odyssey 2. Some games used the left controller and some games used the right controller. There is no consistency in the actual machine. The emulator is emulating it exactly how the real system is. So you need to switch back and forth depending on the game. Your best bet is to make a seperate retroarch config file for all the games that are backwards.
                            tigerinatlanta @edmaul69
                            @edmaul69 - So when you say switch back and forth.. You mean physically between the joysticks correct?? Thanks!
                              edmaul69 @tigerinatlanta
                              @tigerinatlanta yes thats what i mean. so to fix you need to make individual configs for each backwards game and you need to place them in the roms folder. so if you have frogger.bin you need to make a config file called frogger.bin.cfg and inside you add these lines:
                              input_player1_joypad_index = "1"
                              if it is a .zip replace .bin with .zip. remember caps matter
                                tigerinatlanta
                                WOW Thank you so much @edmaul69 . That did the trick. I am able to do play the game appropriately with only 1 joystick. The only remaining issue is I cant exit out of the game now via joystick or keyboard. Is there another input command I can add to the config to do that, or do I need to purchase another controller? You are the man!!
                                herb_fargusH edmaul69E 2 Replies Last reply Reply Quote 0
                                • herb_fargusH
                                  @tigerinatlanta hotkeys only work with player one
                                    tigerinatlanta
                                    Ok thanks @herb_fargus . One final question please. If I hook up a 2nd controller will that enable me to escape out of the game using the hotkeys?
                                      @tigerinatlanta do you have a hotkey set for the keyboard? You should set one in /opt/retropie/configs/all/retroarch.cfg. I choose ctrl personally. Then you can use ctrl and escape to exit. If you dont have hotkey set it forces you to use hotkey button on controller to use the keyboard.
                                      • herb_fargusH
                                        @tigerinatlanta if the second controller is set as player1 in the index as above yes
                                          @edmaul69 said in Odyssey/VIdeopac Controller Player 1 doesn't work:
                                          Hi @edmaul69 I am not sure
                                          Here is what I found in that .cfg file. I added the last line with the "Ctrl" but it seemed to make no difference
                                          Any suggestions on the coding? THanks
                                          Key to exit RetroArch cleanly.
                                          Killing it in any hard way (SIGKILL, etc) will terminate RetroArch without saving RAM, etc.
                                          On Unix-likes, SIGINT/SIGTERM allows a clean deinitialization.
                                          input_exit_emulator = "escape"
                                          input_exit_emulator = "ctrl"
                                            @tigerinatlanta you set 2 exit buttons. you need a hotkey
                                            input_enable_hotkey = "ctrl"
                                            if you put this at the bottom of the file it will override other options disabling it
