retropie-mount apparently not working
So, i was using my 32 GB sd card to storage all my games, but since i full it so fast and i still have a lot of games to play, i bought a 1TB hdd. I follow this guide (https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive) to install the games in my hdd. It says that the games will be transfered to the HDD. I did all the automatic mount steps, now my games didn't appear at the retropie screen, so i hope they are being copied while this. But it's been a hour since it started and no game appear since then (i restarted the emulationstation) Is something wrong happen on the proccess or it's normal cause i had the micro SD almost full? How much time i should wait?
@vahnxdean i think you may need to restart the whole system
thanks, it took a while but now is done :)
