    [Rpi3] RGUI problem with snes emulators
    raspberryrguiretroarchretroarch menusnes
    5 Posts 2 Posters 1.5k Views
      Chuck_B
      Hello! I was editing the file /opt/retropie/configs/snes/retroarch.cfg because i wanted to change some video settings. When i finished to edit it, I've found a strange behaviour of Snes emulators when pressing the RGUI Key while playing.
      Instead of having this kind of RGUI alt text
      i'm getting the classical retroarch view, similar to this
      How do i bring back the first style RGUI?
        mitu Global Moderator @Chuck_B
        @chuck_b Edit the /opt/retropie/configs/all/retroarch.cfg and find the line with menu_driver, change it to be
        menu_driver = "rgui"
          Chuck_B @mitu
          @mitu in that file there is no menu_driver = "rgui" line.
          You also need to know, that I'm having this problem just with snes emulators, while nes and other sistems emulators have the "Green Style" rgui
            @chuck_b Oh, so in this case check the /opt/retropie/configs/snes/retroarch.cfg file. Even if it's not in there, since the default value for this setting isxmb (blue GUI that you're seeing) you can try adding it to see If it makes a difference.
            In case you want to revert to the default, this is the contents of a stock config file for the SNES system:
            input_remapping_directory = "/opt/retropie/configs/snes/"
              Chuck_B @mitu
              @mitu Perfect! Now RGUI it's back.
              menu_driver = "xmb" was in snes/retroarch.cfg, deleting that line fixed it.
              Thank you very much :)
