    GPIO Pins for Adio Output speaker?
    gpiospeakerraspberry pi 3b
    3 Posts 2 Posters 1.6k Views
    • N
      NickoBlack
      I have my RetroPie on my Raspberry Pi 3 Model B, and lately obtain the follow Speaker :
      https://www.adafruit.com/product/1669
      And i wanted to know if it is possible to connect them to the GPIO Pins and configure it so the audio comes out.
      Pin 5 & 6 are already in use for power switch.
      Thank you.
      • caver01C
        caver01 @NickoBlack
        @nickoblack No, not directly. You will need to connect those to an amplifier. Check the link you posted and look at the adafruit description. They list a few options for amplifiers.
        They also make this device which is closer to what you want to do, but it requires software drivers and configuration. I am not familiar with how well it might work, so you are on your own.
        Personally, I would just use one of the cheap amps suggested and connect it to the line out jack.
        • N
          NickoBlack
          Alright thank you.
