    1.8TFT SPI 128*160 V1.1 screen not working with RaspberryPi please help :(
    1.8tft spi 128screenraspi zero w
    35 Posts 5 Posters 5.5k Views
    • retroprogrammerR
      retroprogrammer
      @Hex No still same problem
      Here is me converting the original Xbox for a case:
      https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
      Check out my GitHub: https://github.com/retro-programmer
      • retroprogrammerR
        retroprogrammer
        @Hex Is their a way of making the screen a bit bigger?
        • HexH
          Hex
          how about bgr=0
          The problem is that your blue and red channels are switched and this is the only way to resolve this. If this doesnt work then you will have to try different device names as some device_names dont support the BGR parameter (let me know if you need those).
          From the author of fbtft:
          bgr :
          Set BGR bit (supported by some drivers). Use if Red and Blue is swapped. Default is don't touch.
          The best way is to buy a new screen that is bigger. Else you could try my Viper frontend, which is in works currently. Even i was unhappy with the performance of ES on smaller screens. Here are some of the photos of my frontend. The screen is 320x240 @ 2.2inch.
          Gamelist with images
          • retroprogrammerR
            retroprogrammer
            @hex said in 1.8TFT SPI 128*160 V1.1 screen not working with RaspberryPi please help :(:
            how about bgr=0
            @Hex bgr=0 doesn't work either, I think the red and blue are swapped around or something, I need to know the device_ names please.
            • HexH
              Hex
              Take a look at this thread. the author also had the same problem and was able to get it resolved https://github.com/notro/fbtft/issues/156
              • N
                Nochii
                I use 1.8TFT that similar the red board one but it use st7735S. I config following the tutorial but no luck the screen keep white. what should I do ; w;
                  juj
                  I recently added support for 160x128 ST7735R display to my https://github.com/juj/fbcp-ili9341 display driver. Perhaps it is close enough to ST7735S that it might work there as well by reusing ST7735R options, if you're interested to hack on it a little.
                  • N
                    Nochii @juj
                    @juj I try this command:
                    git clone https://github.com/juj/fbcp-ili9341.git
                    cd fbcp-ili9341
                    mkdir build
                    cd build
                    cmake -DST7735R=ON -DPI_ZERO=ON -DGPIO_TFT_DATA_CONTROL=24 -DGPIO_TFT_RESET_PIN=25 -DSPI_BUS_CLOCK_DIVISOR=6 ..
                    make -j
                    sudo ./fbcp-ili9341
                    (I use pi zero not zero w)
                    I use https://www.aliexpress.com/item/1-8-inch-TFT-LCD-Display-module-ST7735S-128x160-51-AVR-STM32-ARM-8-16-bit/2055099048.html?spm=2114.search0204.3.30.14dd7e5bb5f8hn&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10151_10065_10344_10068_10342_10343_5722611_10340_10341_10696_5722911_5722811_5722711_10084_10083_10618_10307_10059_100031_10103_10624_10623_10622_10621_10620_5722511-10620normal#cfs,searchweb201603_11,ppcSwitch_2_ppcChannel&algo_expid=320e54af-4cc8-48be-be2c-2dc33de19d12-4&algo_pvid=320e54af-4cc8-48be-be2c-2dc33de19d12&priceBeautifyAB=0
                    and connect with
                    LED 23
                    SCK 11
                    SDA 10
                    A0 24
                    RESET 25
                    CS 8
                    GND GND
                    VCC 3V3
                    but it does not work what I do wrong? (I quite new to Raspberry Pi)
                      juj
                      Not exactly sure, the initialization does look good. Try checking through the FAQ and Troubleshooting list if anything in there particular might be relevant: https://github.com/juj/fbcp-ili9341#faq-and-troubleshooting . If not, it might be that there's something essentially different between ST7735R and ST7735S that will need to be taken into account. If you find the spec sheets for both, perhaps you'll be able to spot a crucial difference?
                      • N
                        Nochii @juj
                        @juj Thank you, I think I should try change the GPIO pin if any progress I will report again :)
