    Issue with joypad order when using lr-fbalpha
    joypad orderlr-fbalpha
    1 Posts 1 Posters 571 Views
    • BobHarrisB
      BobHarris
      Hi all,
      I am considering adding a dedicated controller to my setup for my fighting games in fba (don't know yet which controller).
      Ideally I leave this controller hooked up to my Pi and when I start a game in fba it automatically makes this controller the player 1 controller. For all other emulators I use a Dual shock 4.
      But there is something strange going on with lr-fbalpha. In port #0 I have my DS4 and in port #1 I have an arcade stick (HRAP 4).
      I then changed the joypad order for fba (retropie setup -> configuration/tools -> configedit -> configure basic libretro emulator -> options -> fba -> choose joypad order) and changed the order where the arcade stick is now on top and the DS4 below it.
      When I launch for example SF III Third strike the emulator shows that both controllers are recognized (in the bottom left corner), but the DS4 does nothing. I can use the arcade stick and it works fine untill I need a continue. You have to press Start to continue and then suddenly I am controlling player 2 as well with the arcade stick.
      Here is a video (I triggered it just by pressing Start in the character select menu):
      lr-alpha2012 uses the same config file (/opt/retropie/configs/fba/retroarch.cfg) , but actually works without issues. (Sadly most of my roms only work with lr-fbalpha.) Just to verify this problem is isolated to lr-fbalpha, I also changed the joypad order for psx and that is working fine as well. So only the emulator I need to change gives me these problems.. :')
      I updated lr-fbalpha from source but the issue persists.
      (When I don't change the joypad order, then both controllers work fine in lr-fbalpha. But then I'd always have to start every fight on the right side of the screen with my fightpad/fightstick.)
      Pi Model or other hardware: Pi 3B
      Power Supply used: (If using a Pi): Official Pi adapter
      RetroPie Version Used : 4.3.5
      Built From: Got 4.2 from the Retropie site and updated from there.
      USB Devices connected:, Logitech mouse and Microsoft keyboard, Sandisk 128 gb Ultra usb drive
      Controller used: Tried several controllers : Xbox 360, DS4, PS1, Hori RAP4
      Pi 3B , 64 GB Sandisk ultra flashdrive, 19 systems, 872 hand picked classic gaming gems :-) Dual shock 4v2
