    TyrQuake right analog stick issue
    tyrquake
    1 Posts 1 Posters 575 Views
      radicalnetwork
      Hi guys, i'm totally new to the forums and to Retropie aswell.
      I have a problem, i installed TyrQuake (on Retropie 4.3, Pi 3 B) and all the necessary files (wads and music) and everything seems to work perfectly, except for the right analog stick of my gamepad which has the "look up" and "look down" inputs inverted and i really can't play the game like this.
      I've been doing some searching and i found this thread https://retropie.org.uk/forum/topic/9789/disable-reverse-the-right-stick-up-down-stock-invert-for-libretro-tyrquake
      The users there say it's enough to add a couple of lines to the retroarch.cfg to make everything work, but every time i do so and then i boot the game, the gamepad just stops working altogether, and i'm not even able to exit the game or doing anything else.
      It's probably some stupid mistake but as i said i'm very new to this and i don't have a great grasp of the editing process etc., i tried reading the instructions here
      https://github.com/RetroPie/RetroPie-Setup/wiki/RetroArch-Configuration
      but i still can't figure out this stuff.
      So, is anyone able to tell me exactly how my retroarch.cfg file should look to fix this issue?
