    Will retroarch settings carry over if I switch emulators?
    ppssppretroarch cfg
    2 Posts 2 Posters 533 Views
      ryanh1323
      I was wondering if I set up things like skip rate and other audio settings in retroarch for ir-ppsspp if I switch emulators to ppsspp will the settings carry over or do they change back to default when you switch emulators?
      The reason I ask is because I’m trying to get vice city to work on my pi3 and I’m having issues with ppsspp not allowing hot keys so I can’t change things like skip rate to make it run better. Everything else seems to work fine but it’s too slow to play. Also when I use ir-ppsspp I get a totally black screen but I can hear the game playing and controlls seem to be working judging by the corosponding background music.
      I wonder if I change the settings in ir-ppsspp then close out and switch the emulator back to ppsspp will my settings carry over or are they emulator specific?
      I have been trying to fix the hot key issue in ppsspp and I’ve tried to change video settings to get ir-ppsspp to work with no luck. I know at some point I will get one of them to work so this is more of just any FYI question.
        edmaul69 @ryanh1323
        @ryanh1323 no retroarch settings only work in libretrocores. All emulators that start with lr- are libretrocores. If you had two libretro emulators like lr-fceumm and lr-nestopia for nes then all settings in the retroarch.cfg for nes would work on both. However core settings are different and only work on that core
