Player 2 still not working!
ah ok if all is well in emulation station youll be fine its a mame issue
i think you might have accidently remapped some buttons seeing your menu is going on when your in mame from the other post did you delete the cfg files to reset mame to defaults ?
make sure mame isint running
rm /home/pi/RetroPie/roms/mame-libretro/mame2003/mame2003/cfg/*
this is assuming your roms are in /home/pi/RetroPie/roms/mame-libretro/mame2003/
start mame again
@grant2258 it says no such file or directory
If it helps I am using my arcade folder.
do you have ftp access the forum took the spaces away but do me a favor
type ls /home/pi/RetroPie/roms/arcade/mame2003/cfg
if there is files in there do a
rm /home/pi/RetroPie/roms/arcade/mame2003/cfg/*if they arent there they must be in the mame 2003 with spaces
@grant2258 Done, what do I do know?
btw I appreciate you doing this. -
restart mame and see if you 1942 is ok from the other thread or was it 1943
@grant2258 THANK YOU SOOOOO MUCH you solved both my problems! If I had ANY money I would pay you. Thank You SOO MUCH!!!!
@saint_jimmy no problems mate it was an easy mistake ive done it myself sometimes you accidently go into mame and change the buttons by pressing the 8th button. #
if this happens again
us the rm command :)
Same here. Running Rasbian Jessie and having all packages up-to-date both Jessie and Retropie updated. I have the output of
lsusb
Bus 001 Device 018: ID 0079:0006 DragonRise Inc. Generic USB Joystick
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
and the output ofls /opt/retropie/configs/all/retroarch/autoconfig
DragonRise Inc. Generic USB Joystick .cfg DragonRise Inc. Generic USB Joystick .cfg.bak2
DragonRise Inc. Generic USB Joystick .cfg.bakI have tried to manual add
_player2
to the button config so I have 2 .bak files in this dir:
/opt/retropie/configs/all/retroarch-joypads
-rw-r--r-- 1 pi pi 605 Dec 7 15:00 DragonRise Inc. Generic USB Joystick .cfg
-rw-r--r-- 1 pi pi 733 Dec 7 14:24 DragonRise Inc. Generic USB Joystick .cfg.bak
-rw-r--r-- 1 pi pi 605 Dec 7 14:19 DragonRise Inc. Generic USB Joystick .cfg.bak2Here is the current .cfg:
input_device = "DragonRise Inc. Generic USB Joystick "
input_driver = "udev"
input_l_btn = "4"
input_load_state_btn = "4"
input_start_btn = "9"
input_exit_emulator_btn = "9"
input_up_axis = "-1"
input_a_btn = "2"
input_b_btn = "1"
input_reset_btn = "1"
input_enable_hotkey_btn = "8"
input_down_axis = "+1"
input_r_btn = "5"
input_save_state_btn = "5"
input_r2_btn = "7"
input_right_axis = "+0"
input_x_btn = "3"
input_menu_toggle_btn = "3"
input_select_btn = "8"
input_y_btn = "0"
input_left_axis = "-0"
input_l2_btn = "6"And I have no idea how to move forward now...
@jp Please open a new topic and state your problem, don't resurect old - resolved - topics. Add the information requested in https://retropie.org.uk/forum/topic/3/read-this-first when opening the new topic.
