    MCP23017 and Retropie, some problem appears
    mcp23017gpiocontrollerrecalbox
    40 Posts 5 Posters 8.2k Views
      StoneSet
      Hi everyone,
      Recently I received some chips :
      MCP23017 !
      Pi Model : Zero (not W !)
      Power Supply used: 5 amp 5 V
      RetroPie Version : 4.3
      Built From: pre made img
      USB Devices connected: Wifi, and usb controller
      Error messages received: 404 and many other
      Guide used: https://github.com/recalbox/mk_arcade_joystick_rpi
      Attachment of config files: https://pastebin.com/sM1Peg9X
      But i have some problem with installation...
      So I followed this tutorial :
      https://github.com/recalbox/mk_arcade_joystick_rpialt text
      But i can't install this module :
      mk_arcade_joystick
      They are many errors (404 and 403) when I run this script :
      wget https://github.com/recalbox/mk_arcade_joystick_rpi/releases/download/v0.1.4/install.sh
      Did you have a alternative, to use a mcp23017 with retropie ?
      Thanks a lot !
      Best regards,
      http://stoneset.github.io
      • rbakerR
        rbaker @StoneSet
        @stoneset said in MCP23017 and Retropie, some problem appears:
        MCP23017
        Why are you using this extender? Why not the GPIO directly?
          StoneSet
          Because i have a 3.2 TFT screen, so the gpio are already used
          Also, with the screen, i don't have enough gpio to connect all the button (ABXYUPDOWNLEFTRIGHTRLHOTKEY)
          Thanks for your reply
          Best regards,
          • rbakerR
            rbaker @StoneSet
            @stoneset Post a circuit diagram of what you built?
              StoneSet
              Okay !
              (https://www.raspberrypi-spy.co.uk/2013/07/how-to-use-a-mcp23017-i2c-port-expander-with-the-raspberry-pi-part-1/)
              I have been detect the chip :
              pi@raspberrypi ~ $ sudo i2cdetect -y 0
              0 1 2 3 4 5 6 7 8 9 a b c d e f
              00: -- -- -- -- -- -- -- -- -- -- -- -- --
              10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
              20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
              30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
              40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
              50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
              60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
              70: -- -- -- -- -- -- -- --
              (Instead the led, i have button)
              Best regards,
              rbakerR 2 Replies Last reply Reply Quote 0
              • rbakerR
                rbaker @StoneSet
                Well an LED is an output device! Replacing it with a button if you have built the example on the breadboard you linked could be a bad idea. I know the pins are bi-directional on that device but still, the software should be using I2C - is this something that you know is configured correctly? Have you built retropie from scratch or are you using the official image? I think you might need to enter the Pi configuration settings to enable I2C but this may be a raspi config setting only as opposed to a retropie thing. Also, the breadboard layout could be wrong in the graphic. Normally, you need to bridge the power rails at half way - see the actual photo - did you do this? This is a common mistake.
                • rbakerR
                  rbaker @StoneSet
                  @stoneset Did you replace the 330 resistors with 10k? for your switches? The LEDs are being "driven". If switches are to be placed there as a direct replacement, they will not work. This is because the pins of the chip will be floating when the switch is not pressed. They need holding high.
                    StoneSet
                    No, i forget to replace the 330 ohm resistor
                    But, i see the chip when i do "sudo i2cdetect -y 0".
                    The problem, isn't hardware, but software
                    They are another library for the mcp23017, and retropie ?
                    Best regards,
                    mituM rbakerR 2 Replies Last reply Reply Quote 0
                      mitu Global Moderator @StoneSet
                      RetroPie is not an OS, but just uses Raspbian Lite underneath, so any library geared for Raspbian should work on a RetroPie image.
                        StoneSet
                        Okay !
                        But how can I link the gpio controller to retropie ?
                        With a command ?
                        Best regards,
                          @stoneset You'll need a driver - seems you have picked mk_arcade_joystick_rpi - to make your GPIO input appear as a joystick/gamepad, after that you just configure the gamepad in Emulationstation and then use it in your games.
                            StoneSet
                            But I can't install mk_arcade_joystick_rpi
                            As i say early, i have 404 errors with the script:
                            Best regards,
                            • rbakerR
                              rbaker @StoneSet
                              It could be. Unless you have a full circuit diagram of your design, it's not going to be possible to check for sure.
                              • rbakerR
                                rbaker @StoneSet
                                @stoneset Also is your Reset pin definitely high? Remember "Not RST" means low to reset - active low. Must be held high to run.
                                  StoneSet
                                  At this time, i don't have a full circuit diagram
                                  Here is the log when i try to run the script :
                                  https://pastebin.com/zZRM4ZmS
                                  And the reset pin is connected to 3.3V
                                  Best regards,
                                    Just use the manual installation method from the github project page. The automated script tries to install something that's no longer available to download - there's nothing to fix that.
                                    • simonsterS
                                      simonster
                                      Hi @StoneSet
                                      Contary to @mitu's suggestion, I wouldn't follow the manual install. If you have already followed the manual install, you will probably now have overwritten your gcc with an old version after the first instruction, which may cause problems. You may need to update gcc back to the current build first.
                                      I would suggest installing using the mk_arcade_joystick in the retropie_setup script (this will do all that the install.sh would have done). Then following the instructions on the github page from More Joysticks Case downwards.
                                      Si
                                      mituM 1 Reply Last reply Reply Quote 1
                                        mitu Global Moderator @simonster
                                        @simonster is right - the mk_arcade_joystick driver is already included in the RetroPie-Setup script, in the driver section. So you just need to install it from setup script and continue on.
                                          StoneSet
                                          @mitu said in MCP23017 and Retropie, some problem appears:
                                          mk_arcade_joystick
                                          Hi thanks for your reply,
                                          I installed the driver with the script, but when I run :
                                          sudo modprobe mk_arcade_joystick_rpi map=1,0x20
                                          The module was not found....
                                          Do you have any suggestion ?
                                          Best regards,
                                          when I run : dpkg-query -l
                                          I get :
                                          ii mk-arcade-joystick-rpi-dkms 0.1.4 all mk_arcade_joystick_rpi driver in DKMS format.
                                          I also try : mk-arcade-joystick-rpi-dkms
                                          mkarcadejoystick
                                          Best regards,
                                            StoneSet
                                            I also get this erros when i try to run :
                                            sudo dpkg -i mk-arcade-joystick-rpi-0.1.4.deb
                                            (Reading database ... 89823 files and directories currently installed.)
                                            Preparing to unpack mk-arcade-joystick-rpi-0.1.4.deb ...
                                            Deleting module version: 0.1.4
                                            completely from the DKMS tree.
                                            Done.
                                            Unpacking mk-arcade-joystick-rpi-dkms (0.1.4) over (0.1.4) ...
                                            Setting up mk-arcade-joystick-rpi-dkms (0.1.4) ...
                                            Loading new mk_arcade_joystick_rpi-0.1.4 DKMS files...
                                            First Installation: checking all kernels...
                                            dpkg: warning: version '-' has bad syntax: version number does not start with digit
                                            It is likely that 4.9.77+ belongs to a chroot's host
                                            Building for architecture armv6l
                                            Module build for the currently running kernel was skipped since the
                                            kernel source for this kernel does not seem to be installed.
                                            Best regards,
