    Generic USB SNES Controller Not Working
    usb conttrolernot working
    4 Posts 2 Posters 3.2k Views
    • I
      IamMoansss
      Hello,
      I built my raspberry pi set up last night using a raspberry pi zero NO WIFI transferred all my games onto it using a USB stick and using a PS4 Controller for setup but when I plug my Generic USB SNES Controllers i got off eBay in nothing happens these work on my PC running windows 10 without installing any drivers. When using them on retroarch the driver that pops up when a rom is loading is Retrolink_(S)NES_USB I have found the config file in the retroarch folders and the config file says input_driver = "xinput"
      input_device = "Retrolink classic (S)NES USB" but on the raspberry pie in retoarch setting I do not have this driver.
      How can I get this working I have bought 2 retropies and four of these controllers because I have seen people use generic USB controllers on youtube without any issues and after searching all night last night I couldn't find anything that could guide me to resolve this issue. I cannot connect my pi to wifi to perform any updates to see if that would help. I cannot get any keyboard I own to work either so I cannot input any code in the main screen to see if my pie is even registering the generic USB SNES controller
      I downloaded the retropie image last night from here and extracted it using 7zip and used win32diskimager to put it on my SD card. I am new to Linux based systems the internet just makes everything look so easy so you want to do it as well but it is never as easy as it seems lol. I can use windows and never touched a mac before. I prefer taking things apart and fixing hardware this software stuff is long and confusing.
      Thank you for any help in advance
      Kind regards,
      Ben
        mitu Global Moderator @IamMoansss
        @iammoansss The xinput driver is windows specific, so I assume when you're talking about RetroArch you mean you've tested it on Windows. It's going to be hard to diagnose things without a keyboard/network, but why doesn't your keyboard work ? Are you connecting the devices directly or through an USB hub/similar ?
        • I
          IamMoansss
          @mitu said in Generic USB SNES Controller Not Working:
          Sorry yes I was testing them on a windows machine I have a HyperSpin set up on windows.
          Don't Know why my keyboards are not working I'm connecting everything though a OTG hub as the pi zero only has 2 micro USB sockets. Everything else is working USB flasdrive PS4 controller tried them in every port and they are fine just not my basic dell keyboard and generic usb snes controllers.
          I also connected my iPhone to the pi to try a tether the internet (read somewhere you can do that) but nothing happened just charged my iPhone lol
          I have ordered a new Raspberry pi zero W and a USB WIFI dongle for my current zero. To see updating everything would work but it is a brand new version of retropie download last night 24.01.18 :S
          • I
            IamMoansss
            I have a raspberry pi zero w but I have 4 snes usb controllers and a zero delay usb encoder not working. I have tried an old 3rd party usb xbox 360 controller works with no issues.
            please have a look at what results I am getting on ssh. looks like the snes style controllers is not even being recognized by the pi :S I have updated and upgraded this is a brand new image of retropie 4.3 any help would be appreciated thanks :)
            pi@retropie:~ $ lsusb
            Bus 001 Device 002: ID 05e3:0606 Genesys Logic, Inc. USB 2.0 Hub / D-Link DUB-H4 USB 2.0 Hub
            Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
            pi@retropie:~ $ sudo dmesg -c
            [ 0.000000] Booting Linux on physical CPU 0x0
            [ 0.000000] Linux version 4.9.35+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 Fri Jun 30 14:34:49 BST 2017
            [ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
            [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
            [ 0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
            [ 0.000000] cma: Reserved 8 MiB at 0x0f400000
            [ 0.000000] Memory policy: Data cache writeback
            [ 0.000000] On node 0 totalpages: 65536
            [ 0.000000] free_area_init_node: node 0, pgdat c0914874, node_mem_map cfdabe00
            [ 0.000000] Normal zone: 576 pages used for memmap
            [ 0.000000] Normal zone: 0 pages reserved
            [ 0.000000] Normal zone: 65536 pages, LIFO batch:15
            [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
            [ 0.000000] pcpu-alloc: [0] 0
            [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64960
            [ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:04:AD:62 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=3d24ca30-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait loglevel=3 consoleblank=0 plymouth.enable=0
            [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
            [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
            [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
            [ 0.000000] Memory: 241256K/262144K available (5946K kernel code, 489K rwdata, 1948K rodata, 400K init, 734K bss, 12696K reserved, 8192K cma-reserved)
            [ 0.000000] Virtual kernel memory layout:
            vector : 0xffff0000 - 0xffff1000 ( 4 kB)
            fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
            vmalloc : 0xd0800000 - 0xff800000 ( 752 MB)
            lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
            modules : 0xbf000000 - 0xc0000000 ( 16 MB)
            .text : 0xc0008000 - 0xc05d6bbc (5947 kB)
            .init : 0xc0840000 - 0xc08a4000 ( 400 kB)
            .data : 0xc08a4000 - 0xc091e728 ( 490 kB)
            .bss : 0xc091e728 - 0xc09d5f28 ( 734 kB)
            [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
            [ 0.000000] NR_IRQS:16 nr_irqs:16 16
            [ 0.000029] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
            [ 0.000060] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
            [ 0.000152] bcm2835: system timer (irq = 27)
            [ 0.000602] Console: colour dummy device 80x30
            [ 0.000624] console [tty1] enabled
            [ 0.000651] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
            [ 0.060302] pid_max: default: 32768 minimum: 301
            [ 0.060724] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
            [ 0.060741] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
            [ 0.061799] Disabling cpuset control group subsystem
            [ 0.062004] CPU: Testing write buffer coherency: ok
            [ 0.062061] ftrace: allocating 21712 entries in 64 pages
            [ 0.176731] Setting up static identity map for 0x8200 - 0x8238
            [ 0.178671] devtmpfs: initialized
            [ 0.187843] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
            [ 0.188246] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
            [ 0.188273] futex hash table entries: 256 (order: -1, 3072 bytes)
            [ 0.189546] pinctrl core: initialized pinctrl subsystem
            [ 0.190982] NET: Registered protocol family 16
            [ 0.193480] DMA: preallocated 1024 KiB pool for atomic coherent allocations
            [ 0.203219] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
            [ 0.203234] hw-breakpoint: maximum watchpoint size is 4 bytes.
            [ 0.203337] Serial: AMBA PL011 UART driver
            [ 0.206102] bcm2835-mbox 2000b880.mailbox: mailbox enabled
            [ 0.206921] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
            [ 0.254979] bcm2835-dma 20007000.dma: DMA legacy API manager at d080d000, dmachans=0x1
            [ 0.257717] SCSI subsystem initialized
            [ 0.257980] usbcore: registered new interface driver usbfs
            [ 0.258098] usbcore: registered new interface driver hub
            [ 0.258296] usbcore: registered new device driver usb
            [ 0.266800] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-03 14:16
            [ 0.268747] clocksource: Switched to clocksource timer
            [ 0.324995] VFS: Disk quotas dquot_6.6.0
            [ 0.325110] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
            [ 0.325410] FS-Cache: Loaded
            [ 0.325763] CacheFiles: Loaded
            [ 0.345066] NET: Registered protocol family 2
            [ 0.346404] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
            [ 0.346458] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
            [ 0.346510] TCP: Hash tables configured (established 2048 bind 2048)
            [ 0.346603] UDP hash table entries: 256 (order: 0, 4096 bytes)
            [ 0.346629] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
            [ 0.346937] NET: Registered protocol family 1
            [ 0.347684] RPC: Registered named UNIX socket transport module.
            [ 0.347695] RPC: Registered udp transport module.
            [ 0.347699] RPC: Registered tcp transport module.
            [ 0.347704] RPC: Registered tcp NFSv4.1 backchannel transport module.
            [ 0.349014] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
            [ 0.351412] workingset: timestamp_bits=14 max_order=16 bucket_order=2
            [ 0.371331] FS-Cache: Netfs 'nfs' registered for caching
            [ 0.373055] NFS: Registering the id_resolver key type
            [ 0.373103] Key type id_resolver registered
            [ 0.373109] Key type id_legacy registered
            [ 0.377537] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
            [ 0.377906] io scheduler noop registered
            [ 0.377918] io scheduler deadline registered (default)
            [ 0.378381] io scheduler cfq registered
            [ 0.384310] BCM2708FB: allocated DMA memory 4f500000
            [ 0.384370] BCM2708FB: allocated DMA channel 0 @ d080d000
            [ 0.428351] Console: switching to colour frame buffer device 228x61
            [ 0.464959] bcm2835-rng 20104000.rng: hwrng registered
            [ 0.465134] vc-cma: Videocore CMA driver
            [ 0.465143] vc-cma: vc_cma_base = 0x00000000
            [ 0.465152] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
            [ 0.465158] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
            [ 0.465614] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
            [ 0.493977] brd: module loaded
            [ 0.507685] loop: module loaded
            [ 0.507705] Loading iSCSI transport class v2.0-870.
            [ 0.508694] usbcore: registered new interface driver smsc95xx
            [ 0.508840] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
            [ 0.737282] Core Release: 2.80a
            [ 0.737312] Setting default values for core params
            [ 0.737357] Finished setting default values for core params
            [ 0.937823] Using Buffer DMA mode
            [ 0.937837] Periodic Transfer Interrupt Enhancement - disabled
            [ 0.937844] Multiprocessor Interrupt Enhancement - disabled
            [ 0.937855] OTG VER PARAM: 0, OTG VER FLAG: 0
            [ 0.937963] Dedicated Tx FIFOs mode
            [ 0.938685] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xcf514000 dma = 0x4f514000 len=9024
            [ 0.938719] FIQ FSM acceleration enabled for :
            Non-periodic Split Transactions
            Periodic Split Transactions
            High-Speed Isochronous Endpoints
            Interrupt/Control Split Transaction hack enabled
            [ 0.938826] dwc_otg: Microframe scheduler enabled
            [ 0.938949] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04512ec
            [ 0.938965] WARN::hcd_init_fiq:460: FIQ ASM at 0xc04515c8 length 36
            [ 0.938994] WARN::hcd_init_fiq:486: MPHI regs_base at 0xd08a5000
            [ 0.939078] dwc_otg 20980000.usb: DWC OTG Controller
            [ 0.939148] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
            [ 0.939256] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
            [ 0.939308] Init: Port Power? op_state=1
            [ 0.939313] Init: Power Port (0)
            [ 0.939668] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
            [ 0.939684] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
            [ 0.939694] usb usb1: Product: DWC OTG Controller
            [ 0.939703] usb usb1: Manufacturer: Linux 4.9.35+ dwc_otg_hcd
            [ 0.939712] usb usb1: SerialNumber: 20980000.usb
            [ 0.940847] hub 1-0:1.0: USB hub found
            [ 0.940931] hub 1-0:1.0: 1 port detected
            [ 0.941979] dwc_otg: FIQ enabled
            [ 0.941989] dwc_otg: NAK holdoff enabled
            [ 0.941996] dwc_otg: FIQ split-transaction FSM enabled
            [ 0.942019] Module dwc_common_port init
            [ 0.942614] usbcore: registered new interface driver usb-storage
            [ 0.943141] mousedev: PS/2 mouse device common for all mice
            [ 0.945070] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
            [ 0.945600] bcm2835-cpufreq: min=700000 max=1000000
            [ 0.946269] sdhci: Secure Digital Host Controller Interface driver
            [ 0.946278] sdhci: Copyright(c) Pierre Ossman
            [ 0.946793] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
            [ 0.949432] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
            [ 0.949637] sdhci-pltfm: SDHCI platform and OF driver helper
            [ 0.950221] ledtrig-cpu: registered to indicate activity on CPUs
            [ 0.950394] hidraw: raw HID events driver (C) Jiri Kosina
            [ 0.950700] usbcore: registered new interface driver usbhid
            [ 0.950709] usbhid: USB HID core driver
            [ 0.952119] vchiq: vchiq_init_state: slot_zero = 0xcf580000, is_master = 0
            [ 0.954891] Initializing XFRM netlink socket
            [ 0.954956] NET: Registered protocol family 17
            [ 0.955171] Key type dns_resolver registered
            [ 0.957588] registered taskstats version 1
            [ 0.958159] vc-sm: Videocore shared memory driver
            [ 0.958188] [vc_sm_connected_init]: start
            [ 0.965394] [vc_sm_connected_init]: end - returning 0
            [ 0.975009] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
            [ 0.977727] sdhost: log_buf @ cf513000 (4f513000)
            [ 1.048841] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
            [ 1.051491] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
            [ 1.051507] mmc-bcm2835 20300000.mmc: DMA channel allocated
            [ 1.082422] random: fast init done
            [ 1.129010] of_cfs_init
            [ 1.131565] of_cfs_init: OK
            [ 1.137063] Waiting for root device PARTUUID=3d24ca30-02...
            [ 1.147450] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
            [ 1.149645] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            [ 1.151353] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            [ 1.154345] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
            [ 1.159061] Indeed it is in host mode hprt0 = 00021501
            [ 1.231376] mmc0: host does not support reading read-only switch, assuming write-enable
            [ 1.234944] mmc0: new high speed SDHC card at address e624
            [ 1.236467] mmcblk0: mmc0:e624 SS16G 14.8 GiB
            [ 1.240326] mmcblk0: p1 p2
            [ 1.266634] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [ 1.266739] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [ 1.268034] devtmpfs: mounted
            [ 1.269703] Freeing unused kernel memory: 400K (c0840000 - c08a4000)
            [ 1.269715] This architecture does not have kernel memory protection.
            [ 1.334661] mmc1: new high speed SDIO card at address 0001
            [ 1.358878] usb 1-1: new full-speed USB device number 2 using dwc_otg
            [ 1.359267] Indeed it is in host mode hprt0 = 00021501
            [ 1.590786] usb 1-1: New USB device found, idVendor=05e3, idProduct=0606
            [ 1.590807] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
            [ 1.590818] usb 1-1: Product: USB Hub 2.0
            [ 1.590828] usb 1-1: Manufacturer: ALCOR
            [ 1.592316] hub 1-1:1.0: USB hub found
            [ 1.592648] hub 1-1:1.0: 4 ports detected
            [ 1.648255] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
            [ 1.649361] systemd[1]: Detected architecture 'arm'.
            [ 1.795249] NET: Registered protocol family 10
            [ 1.797649] systemd[1]: Inserted module 'ipv6'
            [ 1.803698] systemd[1]: Set hostname to <retropie>.
            [ 1.804317] systemd[1]: Initializing machine ID from random generator.
            [ 1.804996] systemd[1]: Installed transient /etc/machine-id file.
            [ 1.908974] usb 1-1.4: new low-speed USB device number 3 using dwc_otg
            [ 2.448924] usb 1-1.4: new low-speed USB device number 4 using dwc_otg
            [ 2.580673] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
            [ 2.588310] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
            [ 2.589526] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
            [ 2.589753] systemd[1]: Starting Remote File Systems (Pre).
            [ 2.989016] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
            [ 3.057720] fuse init (API version 7.26)
            [ 3.529059] usb 1-1.4: new low-speed USB device number 6 using dwc_otg
            [ 5.030597] systemd-udevd[131]: starting version 215
            [ 7.954295] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            [ 8.022553] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
            [ 9.788675] usbcore: registered new interface driver brcmfmac
            [ 10.032808] brcmfmac: Firmware version = wl0: Aug 7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
            [ 11.102043] systemd-journald[128]: Received request to flush runtime journal from PID 1
            [ 13.754369] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
            [ 13.754412] brcmfmac: power management disabled
            [ 14.670604] uart-pl011 20201000.serial: no DMA platform data
            [ 15.807641] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:266236k SSFS
            [ 16.267412] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
            [ 19.151832] Bluetooth: Core ver 2.22
            [ 19.152033] NET: Registered protocol family 31
            [ 19.152045] Bluetooth: HCI device and connection manager initialized
            [ 19.152083] Bluetooth: HCI socket layer initialized
            [ 19.152103] Bluetooth: L2CAP socket layer initialized
            [ 19.152168] Bluetooth: SCO socket layer initialized
            [ 19.173901] Bluetooth: HCI UART driver ver 2.3
            [ 19.173921] Bluetooth: HCI UART protocol H4 registered
            [ 19.173927] Bluetooth: HCI UART protocol Three-wire (H5) registered
            [ 19.174123] Bluetooth: HCI UART protocol Broadcom registered
            [ 19.516265] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
            [ 19.516279] Bluetooth: BNEP filters: protocol multicast
            [ 19.516310] Bluetooth: BNEP socket layer initialized
            [ 64.073432] random: crng init done
            [ 80.938856] dwc_otg_handle_wakeup_detected_intr lxstate = 2
            [ 82.658902] dwc_otg_handle_wakeup_detected_intr lxstate = 2
            [ 83.129528] usb 1-1.2: new low-speed USB device number 7 using dwc_otg
            [ 83.669310] usb 1-1.2: new low-speed USB device number 8 using dwc_otg
            [ 84.209410] usb 1-1.2: new low-speed USB device number 9 using dwc_otg
            [ 84.749322] usb 1-1.2: new low-speed USB device number 10 using dwc_otg
            [ 1678.184311] dwc_otg_handle_wakeup_detected_intr lxstate = 2
            pi@retropie:~ $ dmesg
            [ 2773.322342] dwc_otg_handle_wakeup_detected_intr lxstate = 2
            [ 2773.844016] usb 1-1.4: new low-speed USB device number 11 using dwc_otg
            [ 2774.383956] usb 1-1.4: new low-speed USB device number 12 using dwc_otg
            [ 2774.923988] usb 1-1.4: new low-speed USB device number 13 using dwc_otg
            [ 2775.463933] usb 1-1.4: new low-speed USB device number 14 using dwc_otg
            Just tried plugging the controller into the pi directly and it is recognised :S why do the PS4 and Xbox 360 controllers work when plugged into the hub but the snes one doesn't. They are getting 4.5-4.6v when plugged into the hub. When connected directly it gets 4.7v I did solder two USB leads on after one for power one for signal. Plugged the power to the pc and signal to the pi got nothing even though it was getting 5v I'm lost with this. Just don't understand why some controllers work and some don't.
