    Help with retropie? (Web Browser)
    rpi3
    9 Posts 4 Posters 3.6k Views
      psw757
      Hi
      I have a pi3 that currently auto boots to retropie.
      I would like to create a link to a website to run another program that I am subscribed to called iscored.
      I'm not sure what I need to do to give me the option of selecting retropie or this other program.
      Anyone able to help?
        mitu Global Moderator @psw757
        @psw757 What's the usage for this ?
          psw757
          The use of the iscored app is just a score keeping application for my pinball machines.
          There is a website iscored.info that has a video explaining it and the rpi3 is one of the devices that runs it well.
          I just don't know how to configure my pi to allow use of the retropie arcade and this app.
            @psw757 RetroPie does not include a web browser or a desktop environment in order to run a web browser. You can install the PIXEL desktop environment and then add Chrome to your installation, see the FAQ page here https://retropie.org.uk/docs/FAQ/#where-did-the-desktop-go
              psw757 @mitu
              Have the pixel downloading right now, is there a tutorial how to get chrome installed.
              Thanks for your guidance with this, this is my first time playing around with the pi.
                psw757
                Well I think I have it working.
                Just a few questions. I'm able to launch the desktop from boots in retropie now.
                Is there a way to create a shortcut to the iscored program or site within retropie boots or on the desktop so I don't have to manually search it in browser?
                Thanks for all the help
                caver01C mituM D 3 Replies Last reply Reply Quote 0
                • caver01C
                  caver01 @psw757
                  @psw757 maybe you can have your PIXEL desktop as a launchable option in RetroPie, then have Chrome load at startup, if that is possible in PIXEL. You would have to research that, but it seems like a reasonable thing to be able to figure out. Then, if you set your iscored site as the home page. . .
                  . . . You should be able to select PIXEL desktop in RetroPie, it will launch desktop GUI, open Chrome at startup, and boom, you should be looking at iScored.
                  Just a thought.
                    @psw757 Open the browser preferences and make the web page your homepage or start-up page - https://support.google.com/chrome/answer/95314?hl=en
                      dudleydes @psw757
                      @psw757 If you want to bypass the desktop, you can install the standalone version of Chromium from the RetroPie Extra Repository. Once it's installed, you can edit the chromium.sh script so that the last line reads:
                      /usr/bin/chromium-browser iscored.info
