    Retropie stuck on kiosk mode and code is not working
    help retropiekiosk kids modestuckkonamicode
    12 Posts 4 Posters 9.3k Views
      Johnny_trevino_1
      Help my retropie is stuck on kiosk mode and the code is not working what can I do
      • lostlessL
        lostless
        I’ve noticed that code doesn’t work anymore as well. You can log into the pi configs and go to all and then emulationstation. There is a config file in there. Not near my pi so I forget what it’s called. But there is a line for what mode Es is in. Change it from KIOSK to FULL
          Johnny_trevino_1 @lostless
          @lostless I've just finished trying that but it didn't work here's how the code looks now did I do anything wrong? Thanks for helping me with this!!
          <String name="UIMode" value="FULL" />
          • lostlessL
            lostless @Johnny_trevino_1
            @johnny_trevino_1 you have to reboot emulation station
              Clyde @Johnny_trevino_1
              @johnny_trevino_1 See the docs on Switching UI modes.
                Johnny_trevino_1 @Clyde
                @clyde awesome thank you so much
                  @lostless awesome thank you so much
                    @johnny_trevino_1 Glad we could help. One little tip about this forum: You could've just put both our names with a leading @ in one post (e.g. @Clyde @lostless Hello!) The forum's software recognizes that and informs all users that are mentioned like this. It even proposes existing user names while typing if you start with an @.
                      rbair6600
                      I can get to <string name="UIMode" value="koisk" /> and change it to full but how do i save it
                        rbair6600
                        or get to the ok and select it
                          rbair6600
                          Got it push tab
                          ClydeC 1 Reply Last reply Reply Quote 1
                            Clyde @rbair6600
                            @rbair6600 Thanks for sharing your solution.
