    Problem run ROMS with comma character
    romsruncommandbug
    20 Posts 6 Posters 2.9k Views
      gleam2003
      When launch roms like this
      Action Fighter (USA, Europe).7z
      System back to emulationstation and no log avviable in /dev/shm
      No problem with roms like
      Alex Kidd - The Lost Stars (World).7z
      Test with other roms with "," and the problem is the same.
        gleam2003
        Help, I don't want to rename all my roms and all my gamelist.
          mediamogul Global Moderator @gleam2003
          @gleam2003
          After launching one of those games, post the contents of /dev/shm/runcommand.log. Also, please post the information requested at https://retropie.org.uk/forum/topic/3/read-this-first.
            gleam2003
            No log was created in /dev/shm, already write it
              gleam2003
              Run EmulationStation from ssh terminal for watch the error, report:
              sh: 1: Syntax error: "(" unexpected
              Pi Model or other hardware: Pi3
              RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.3
              Built From: RetroPie 4.3 clean image
              USB Devices connected: none exept snes style controler
              Controller used: SNES style (type="joystick" deviceName="USB Gamepad " deviceGUID="03000000790000001100000010010000")
              Error messages received: sh: 1: Syntax error: "(" unexpected
              Log found in /dev/shm/runcommand.log (if relevant): No data logged! (work with working roms)
              File: Action Fighter (USA, Europe).7z
              Emulator: all emulator
              How to replicate the problem: use roms with , OR (,) on name
                mitu Global Moderator @gleam2003
                @gleam2003 I have no problem with ROMs having , in their names, either running or showing in Emulationstation. Can you try an update for all packages (from binary) from the RetroPie-Setup and then restart Emulationstation ?
                  gleam2003
                  Update, same issue
                  I test with change the roms name to find when the problem occurs.
                  A space after "(" is the problem. My error is to suppose that the problem is the ","
                  Can you verify?
                    gleam2003
                    @mediamogul @mitu
                    This is the command pass to system() command in runSystemCommand function in platform.cpp
                    /opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS mastersystem /home/pi/RetroPie/roms/mastersystem/Alex\ Kidd\ in\ Miracle\ World\ (USA,\ Europe).7z
                    My EmulationStation is the development version and I think the problem is in StringUtil.cpp that substitute the strreplace function
                      cyperghost
                      This post is deleted!
                        cyperghost
                        @gleam2003 Don't know what going wrong here I just renamed one mastersystem ROM to Alex Kidd in Miracle World (USA, Europe).sms and it worked without any flaws.
                        Does your 7zip file contain more than one ROM?
                          gleam2003 @cyperghost
                          @cyperghost
                          Probably problem is only in development version of emulationstation
                          Wait i'm going to recompile the stable branch to watch if is ok
                            gleam2003
                            I can confirm, the problem is with development tree
                            with stable:
                            /opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS mastersystem /home/pi/RetroPie/roms/mastersystem/Alex\ Kidd\ in\ Miracle\ World\ \(USA,\ Europe\).7z
                            with development:
                            In stable ther's escapePath function, missing completely in development
                              Tomaz
                              I fix this later today when I'm not at work.
                              There is still an escapePath function, it's just moved to a different location in the source.
                              Looking at the output, it seems it didn't escape the last ')' properly.
                                gleam2003 @Tomaz
                                @tomaz
                                Thank you
                                Not only last ) but also ( and I think any other charachter escape in stable branch with escapePath() function
                                Edit: there's a space before (
                                T 2 Replies Last reply Reply Quote 0
                                  Tomaz @gleam2003
                                  @gleam2003
                                  I see now that both ( and ) fails, but the new escapePath function definitely runs since it has escaped all the spaces, will know more when I'm back home later today.
                                    Tomaz @gleam2003
                                    @gleam2003
                                    Fixed and submitted, just need to wait for it to be accepted and merged.
                                      gleam2003 @Tomaz
                                      @tomaz
                                      Thank you, compiled and tested.
                                        Tomaz @gleam2003
                                        @gleam2003
                                        Did the fix work for you? It should be merged in the dev branch now.
                                          gleam2003 @Tomaz
                                          @tomaz
                                          Yes sorry I think you understand from my previous post
                                          • DwarfboysimD
                                            Dwarfboysim
                                            Hi,
                                            There are free utilities that can search an entire folder and remove that one character from all file names. Pretty sure it’s called Bulk Rename Utility. I used it to tidy up all my file names
                                            Dwarfboysim
