    BattleZone mame2003 input issue
    mame2003service menu
    27 Posts 4 Posters 5.1k Views
    • AlturisA
      Alturis
      I was reading the games list and saw that someone said they had gotten mame2003 to run BattleZone (bzone.zip) successfully after they messed with the input bindings in the mame menu.
      The exact quote is:
      "Game automatically pauses and enders service mode when start is pressed. enter MAME menu and key those buttons to the controller for this game, then press them when the game starts. Since this, I have had no issues."
      I have been trying to configure different things in that menu but nothing seems to avoid the issue described. It registers a coin, then when I hit start it opens up the mame2003 service mode.
      Hoping whoever wrote that note could maybe explain a bit more what they mean by "key those buttons."
      RP 4.7.1 • Pi4 4Gig • CanaKit Aluminum • 64GB microSD • 1920x1080 BarTop [2 Sanwa sticks]
        mediamogul Global Moderator @Alturis
        @alturis
        One of the best features of RetroPie is that there's always the option of using another, and in certain cases, more compatible means of emulation. 'Battlezone' not only runs more effectively with a few other solutions, but being a vector game, is much better displayed in AdvanceMame, where it can be rendered in HD. Also, 'Battlezone' makes use of bezel art, as seen below, to complete the cockpit effect that is not compatible with lr-mame2003. Of course, another great feature of RetroPie is that you can ignore all of this and play it anyway you see fit, so my words come only as a recommendation.
        AlturisA FlightRiskF 3 Replies Last reply Reply Quote 3
        • AlturisA
          Alturis @mediamogul
          @mediamogul Yeah I checked out advMame1.4 and it seemed to run it nicer with the old colored glass overlays. I havent been able to get advMame detecting any joypad input yet but I will do some reading thanks.
          Edit: Ah figured it out now. Most of the advMame controls are defaulted to generic button names but when using an xbox 360 controller it needed rebindings of many things. Just need to figure out how to bind something to exit the game now.
          caver01C 1 Reply Last reply Reply Quote 1
          • FlightRiskF
            FlightRisk
            Any help you can provide would be great. I want to do the same. I sold my upright battlezone that I had for over 30 years. Which emulator is best for BZ on a Pi3B? Also, I am not sure what @Alturis meant by BZ being HD in AdvanceMame and that bezel art is not compatible with lr-mame2003. Do you mean for just that game? I use bezel art and shaders for my other roms in lr-mame2003 and they work fine. Also, I would love to find that exact bezel art you are using since that is how it looked in the periscope of the actual game.
              mediamogul Global Moderator @FlightRisk
              @flightrisk said in BattleZone mame2003 input issue:
              There are several options that will simply run the game just fine. However, AdvanceMAME is currently the only option for HD vector rendering, which makes the vector art look very close to how it would on an actual vector monitor. The bezel artwork for AdvanceMAME and lr-mame2003 are not directly compatible. With a little work you could probably adapt the bezel to work in RetroArch, or even find one that's already been created. The artwork file seen above that's compatible with the MAME 0.106 (AdvanceMAME) can usually be found with the ROM set itself.
              • FlightRiskF
                FlightRisk
                Is AvanceMAME3 AdvanceMAME 3.6? I was adding cores just now and saw advmame.94, .104 and then just plain advmame. When installed the third one with no number after it, I watched to see what it installed and it said 3.6. Also, on 104 and 3.6, I noticed at the end of the install it had 10 or so errors that it failed to make symlinks. It flashed by quickly, but looked like it was for all the subfolders under the emulator path. Hope I can ignore that ;)
                Also, will I need to find .106 versions of vector roms? I am using .78 on the Pi3 and much later versions on a PC, but have no intermediate roms.
                Lastly, do I take the artwork out of the zip, or does advmame have a feature that finds it in there? I have all my arcade roms in an arcade folder. So currently am using this path since I have experimented with Retropie bezels only in Retroarch and the classic arcade roms in the arcade folder:
                roms: /home/pi/RetroPie/roms/arcade
                bezels: /opt/retropie/emulators/retroarch/overlays/
                I'm assuming since AdvanceMAME isn't a libretro core, I will have to put things in different places. GitHub lists these paths, but not sure where the bezels would go and how to configure them yet since I have used Retroarch for all that:
                Roms Dir: /home/pi/RetroPie/roms/mame-advmame
                Binary Dir: /opt/retropie/emulators/advmame/bin
                Config Dir: /opt/retropie/configs/mame-advmame
                  It is indeed.
                  Yes. Each version of MAME/AdvanceMAME/FBA requires a specific ROM set to match it.
                  You just leave them zipped and place them at /home/pi/RetroPie/roms/mame-advmame/artwork
                  • FlightRiskF
                    FlightRisk
                    Also, AdvanceMAME is stretching roms like battlezone to almost full screen. So I am trying to track that down. I see some people saying there is/was an issue with 3.x versions of advmame doing this, but hopefully there is an aspect ratio or X/Y resolution setting somewhere.
                      It doesn't do that on mine and it shouldn't be the default behavior. Post the contents of /opt/retropie/configs/mame-advmame/advmame.rc and we'll take a look.
                      FlightRiskF 1 Reply Last reply Reply Quote 0
                      • caver01C
                        caver01 @Alturis
                        @alturis The default exit key is ESC, but you can edit the binding unsing the TAB menu inside AdvanceMAME. Select general controls for all games and edit the UI Cancel binding. You could even set this to START and SELECT simultaneously if you want it to match libretro hotkey exit.
                        I also recommend mapping this game’s controls to use a virtual “tank stick” so you can steer the tank with a single joystick leaving your other hand free to press the fire button:
                        Game Control	Mapped to
                        Right/Up	Up NOT Right or Left NOT Down
                        Right/DownD	Down NOT Right or Right NOT Up NOT Down
                        Left/Up	        Up NOT Left or Right NOT Down
                        Left/Down	Down NOT Left or Left NOT Up NOT Down
                        AlturisA FlightRiskF 2 Replies Last reply Reply Quote 1
                        • AlturisA
                          Alturis @caver01
                          @caver01 Awesome thank you for the tip! Might have to give that control setup a try for it. But to me, the feel of driving it like a two-stick tank as the original arcade was outweighed the difficulty of having to use my pinky to fire.
                          • FlightRiskF
                            FlightRisk @mediamogul
                            @mediamogul Thanks, here is my advmame.rc
                            debug_crash no
                            debug_rawsound no
                            debug_speedmark no
                            device_alsa_device default
                            device_alsa_mixer channel
                            device_color_bgr15 yes
                            device_color_bgr16 yes
                            device_color_bgr24 yes
                            device_color_bgr32 yes
                            device_color_bgr8 yes
                            device_color_palette8 yes
                            device_color_yuy2 yes
                            device_dpi_pclock_low 31250000
                            device_hdmi_pclock_low 0
                            device_joystick auto
                            device_keyboard raw
                            device_mouse auto
                            device_raw_firstkeyhack no
                            device_raw_mousedev[0] auto
                            device_raw_mousedev[1] auto
                            device_raw_mousedev[2] auto
                            device_raw_mousedev[3] auto
                            device_raw_mousetype[0] pnp
                            device_raw_mousetype[1] pnp
                            device_raw_mousetype[2] pnp
                            device_raw_mousetype[3] pnp
                            device_sdl_samples 512
                            device_sound alsa
                            device_video fb
                            device_video_cursor off
                            device_video_doublescan yes
                            device_video_fastchange no
                            device_video_interlace yes
                            device_video_output auto
                            device_video_overlaysize auto
                            device_video_singlescan yes
                            dir_artwork /home/pi/RetroPie/roms/mame-advmame/artwork
                            dir_diff /home/pi/RetroPie/roms/mame-advmame/diff
                            dir_hi /home/pi/RetroPie/roms/mame-advmame/hi
                            dir_image /home/pi/RetroPie/roms/mame-advmame
                            dir_inp /home/pi/RetroPie/roms/mame-advmame/inp
                            dir_memcard /home/pi/RetroPie/roms/mame-advmame/memcard
                            dir_nvram /home/pi/RetroPie/roms/mame-advmame/nvram
                            dir_rom /home/pi/RetroPie/roms/mame-advmame:/home/pi/RetroPie/roms/arcade
                            dir_sample /home/pi/RetroPie/roms/mame-advmame/samples
                            dir_snap /home/pi/RetroPie/roms/mame-advmame/snap
                            dir_sta /home/pi/RetroPie/roms/mame-advmame/nvram
                            display_adjust none
                            display_antialias yes
                            display_artwork_backdrop yes
                            display_artwork_bezel no
                            display_artwork_crop yes
                            display_artwork_overlay yes
                            display_aspect auto
                            display_beam 1
                            display_brightness 1
                            display_buffer no
                            display_color auto
                            display_expand 1.25
                            display_flicker 0
                            display_flipx no
                            display_flipy no
                            display_frameskip auto
                            display_gamma 1
                            display_intensity 1.5
                            display_interlaceeffect none
                            display_magnify 1
                            display_magnifysize 640
                            display_mode auto
                            display_pausebrightness 1
                            display_resize integer
                            display_resizeeffect none
                            display_restore yes
                            display_rgbeffect none
                            display_rol no
                            display_ror no
                            display_scanlines no
                            display_skipcolumns auto
                            display_skiplines auto
                            display_translucency yes
                            display_vsync no
                            include
                            input_hotkey yes
                            input_idleexit 0
                            input_map[event10] auto
                            input_map[event11] auto
                            input_map[event12] auto
                            input_map[event13] auto
                            input_map[event14] auto
                            input_map[event1] auto
                            input_map[event2] auto
                            input_map[event3] auto
                            input_map[event4] auto
                            input_map[event5] auto
                            input_map[event6] auto
                            input_map[event7] auto
                            input_map[event8] auto
                            input_map[event9] auto
                            input_map[p1_dialx] auto
                            input_map[p1_dialy] auto
                            input_map[p1_lightgunx] auto
                            input_map[p1_lightguny] auto
                            input_map[p1_mousex] auto
                            input_map[p1_mousey] auto
                            input_map[p1_paddlex] auto
                            input_map[p1_paddley] auto
                            input_map[p1_pedalbrake] auto
                            input_map[p1_pedalgas] auto
                            input_map[p1_pedalother] auto
                            input_map[p1_stickx] auto
                            input_map[p1_sticky] auto
                            input_map[p1_stickz] auto
                            input_map[p1_trackballx] auto
                            input_map[p1_trackbally] auto
                            input_map[p2_dialx] auto
                            input_map[p2_dialy] auto
                            input_map[p2_lightgunx] auto
                            input_map[p2_lightguny] auto
                            input_map[p2_mousex] auto
                            input_map[p2_mousey] auto
                            input_map[p2_paddlex] auto
                            input_map[p2_paddley] auto
                            input_map[p2_pedalbrake] auto
                            input_map[p2_pedalgas] auto
                            input_map[p2_pedalother] auto
                            input_map[p2_stickx] auto
                            input_map[p2_sticky] auto
                            input_map[p2_stickz] auto
                            input_map[p2_trackballx] auto
                            input_map[p2_trackbally] auto
                            input_map[p3_dialx] auto
                            input_map[p3_dialy] auto
                            input_map[p3_lightgunx] auto
                            input_map[p3_lightguny] auto
                            input_map[p3_mahjong_a] auto
                            input_map[p3_mahjong_b] auto
                            input_map[p3_mahjong_bet] auto
                            input_map[p3_mahjong_c] auto
                            input_map[p3_mahjong_chance] auto
                            input_map[p3_mahjong_chi] auto
                            input_map[p3_mahjong_d] auto
                            input_map[p3_mahjong_double_up] auto
                            input_map[p3_mahjong_e] auto
                            input_map[p3_mahjong_f] auto
                            input_map[p3_mahjong_flip_flop] auto
                            input_map[p3_mahjong_g] auto
                            input_map[p3_mahjong_h] auto
                            input_map[p3_mahjong_i] auto
                            input_map[p3_mahjong_j] auto
                            input_map[p3_mahjong_k] auto
                            input_map[p3_mahjong_kan] auto
                            input_map[p3_mahjong_l] auto
                            input_map[p3_mahjong_m] auto
                            input_map[p3_mahjong_n] auto
                            input_map[p3_mahjong_pon] auto
                            input_map[p3_mahjong_reach] auto
                            input_map[p3_mahjong_ron] auto
                            input_map[p3_mahjong_score] auto
                            input_map[p3_mousex] auto
                            input_map[p3_mousey] auto
                            input_map[p3_paddlex] auto
                            input_map[p3_paddley] auto
                            input_map[p3_pedalbrake] auto
                            input_map[p3_pedalgas] auto
                            input_map[p3_pedalother] auto
                            input_map[p3_stickx] auto
                            input_map[p3_sticky] auto
                            input_map[p3_stickz] auto
                            input_map[p3_trackballx] auto
                            input_map[p3_trackbally] auto
                            input_map[p4_dialx] auto
                            input_map[p4_dialy] auto
                            input_map[p4_lightgunx] auto
                            input_map[p4_lightguny] auto
                            input_map[p4_mahjong_a] auto
                            input_map[p4_mahjong_b] auto
                            input_map[p4_mahjong_bet] auto
                            input_map[p4_mahjong_c] auto
                            input_map[p4_mahjong_chance] auto
                            input_map[p4_mahjong_chi] auto
                            input_map[p4_mahjong_d] auto
                            input_map[p4_mahjong_double_up] auto
                            input_map[p4_mahjong_e] auto
                            input_map[p4_mahjong_f] auto
                            input_map[p4_mahjong_flip_flop] auto
                            input_map[p4_mahjong_g] auto
                            input_map[p4_mahjong_h] auto
                            input_map[p4_mahjong_i] auto
                            input_map[p4_mahjong_j] auto
                            input_map[p4_mahjong_k] auto
                            input_map[p4_mahjong_kan] auto
                            input_map[p4_mahjong_l] auto
                            input_map[p4_mahjong_m] auto
                            input_map[p4_mahjong_n] auto
                            input_map[p4_mahjong_pon] auto
                            input_map[p4_mahjong_reach] auto
                            input_map[p4_mahjong_ron] auto
                            input_map[p4_mahjong_score] auto
                            input_map[p4_mousex] auto
                            input_map[p4_mousey] auto
                            input_map[p4_paddlex] auto
                            input_map[p4_paddley] auto
                            input_map[p4_pedalbrake] auto
                            input_map[p4_pedalgas] auto
                            input_map[p4_pedalother] auto
                            input_map[p4_stickx] auto
                            input_map[p4_sticky] auto
                            input_map[p4_stickz] auto
                            input_map[p4_trackballx] auto
                            input_map[p4_trackbally] auto
                            input_map[p5_dialx] auto
                            input_map[p5_dialy] auto
                            input_map[p5_lightgunx] auto
                            input_map[p5_lightguny] auto
                            input_map[p5_mahjong_a] auto
                            input_map[p5_mahjong_b] auto
                            input_map[p5_mahjong_bet] auto
                            input_map[p5_mahjong_c] auto
                            input_map[p5_mahjong_chance] auto
                            input_map[p5_mahjong_chi] auto
                            input_map[p5_mahjong_d] auto
                            input_map[p5_mahjong_double_up] auto
                            input_map[p5_mahjong_e] auto
                            input_map[p5_mahjong_f] auto
                            input_map[p5_mahjong_flip_flop] auto
                            input_map[p5_mahjong_g] auto
                            input_map[p5_mahjong_h] auto
                            input_map[p5_mahjong_i] auto
                            input_map[p5_mahjong_j] auto
                            input_map[p5_mahjong_k] auto
                            input_map[p5_mahjong_kan] auto
                            input_map[p5_mahjong_l] auto
                            input_map[p5_mahjong_m] auto
                            input_map[p5_mahjong_n] auto
                            input_map[p5_mahjong_pon] auto
                            input_map[p5_mahjong_reach] auto
                            input_map[p5_mahjong_ron] auto
                            input_map[p5_mahjong_score] auto
                            input_map[p5_mousex] auto
                            input_map[p5_mousey] auto
                            input_map[p5_paddlex] auto
                            input_map[p5_paddley] auto
                            input_map[p5_pedalbrake] auto
                            input_map[p5_pedalgas] auto
                            input_map[p5_pedalother] auto
                            input_map[p5_stickx] auto
                            input_map[p5_sticky] auto
                            input_map[p5_stickz] auto
                            input_map[p5_trackballx] auto
                            input_map[p5_trackbally] auto
                            input_map[p6_dialx] auto
                            input_map[p6_dialy] auto
                            input_map[p6_lightgunx] auto
                            input_map[p6_lightguny] auto
                            input_map[p6_mahjong_a] auto
                            input_map[p6_mahjong_b] auto
                            input_map[p6_mahjong_bet] auto
                            input_map[p6_mahjong_c] auto
                            input_map[p6_mahjong_chance] auto
                            input_map[p6_mahjong_chi] auto
                            input_map[p6_mahjong_d] auto
                            input_map[p6_mahjong_double_up] auto
                            input_map[p6_mahjong_e] auto
                            input_map[p6_mahjong_f] auto
                            input_map[p6_mahjong_flip_flop] auto
                            input_map[p6_mahjong_g] auto
                            input_map[p6_mahjong_h] auto
                            input_map[p6_mahjong_i] auto
                            input_map[p6_mahjong_j] auto
                            input_map[p6_mahjong_k] auto
                            input_map[p6_mahjong_kan] auto
                            input_map[p6_mahjong_l] auto
                            input_map[p6_mahjong_m] auto
                            input_map[p6_mahjong_n] auto
                            input_map[p6_mahjong_pon] auto
                            input_map[p6_mahjong_reach] auto
                            input_map[p6_mahjong_ron] auto
                            input_map[p6_mahjong_score] auto
                            input_map[p6_mousex] auto
                            input_map[p6_mousey] auto
                            input_map[p6_paddlex] auto
                            input_map[p6_paddley] auto
                            input_map[p6_pedalbrake] auto
                            input_map[p6_pedalgas] auto
                            input_map[p6_pedalother] auto
                            input_map[p6_stickx] auto
                            input_map[p6_sticky] auto
                            input_map[p6_stickz] auto
                            input_map[p6_trackballx] auto
                            input_map[p6_trackbally] auto
                            input_map[p7_dialx] auto
                            input_map[p7_dialy] auto
                            input_map[p7_lightgunx] auto
                            input_map[p7_lightguny] auto
                            input_map[p7_mahjong_a] auto
                            input_map[p7_mahjong_b] auto
                            input_map[p7_mahjong_bet] auto
                            input_map[p7_mahjong_c] auto
                            input_map[p7_mahjong_chance] auto
                            input_map[p7_mahjong_chi] auto
                            input_map[p7_mahjong_d] auto
                            input_map[p7_mahjong_double_up] auto
                            input_map[p7_mahjong_e] auto
                            input_map[p7_mahjong_f] auto
                            input_map[p7_mahjong_flip_flop] auto
                            input_map[p7_mahjong_g] auto
                            input_map[p7_mahjong_h] auto
                            input_map[p7_mahjong_i] auto
                            input_map[p7_mahjong_j] auto
                            input_map[p7_mahjong_k] auto
                            input_map[p7_mahjong_kan] auto
                            input_map[p7_mahjong_l] auto
                            input_map[p7_mahjong_m] auto
                            input_map[p7_mahjong_n] auto
                            input_map[p7_mahjong_pon] auto
                            input_map[p7_mahjong_reach] auto
                            input_map[p7_mahjong_ron] auto
                            input_map[p7_mahjong_score] auto
                            input_map[p7_mousex] auto
                            input_map[p7_mousey] auto
                            input_map[p7_paddlex] auto
                            input_map[p7_paddley] auto
                            input_map[p7_pedalbrake] auto
                            input_map[p7_pedalgas] auto
                            input_map[p7_pedalother] auto
                            input_map[p7_stickx] auto
                            input_map[p7_sticky] auto
                            input_map[p7_stickz] auto
                            input_map[p7_trackballx] auto
                            input_map[p7_trackbally] auto
                            input_map[p8_dialx] auto
                            input_map[p8_dialy] auto
                            input_map[p8_lightgunx] auto
                            input_map[p8_lightguny] auto
                            input_map[p8_mahjong_a] auto
                            input_map[p8_mahjong_b] auto
                            input_map[p8_mahjong_bet] auto
                            input_map[p8_mahjong_c] auto
                            input_map[p8_mahjong_chance] auto
                            input_map[p8_mahjong_chi] auto
                            input_map[p8_mahjong_d] auto
                            input_map[p8_mahjong_double_up] auto
                            input_map[p8_mahjong_e] auto
                            input_map[p8_mahjong_f] auto
                            input_map[p8_mahjong_flip_flop] auto
                            input_map[p8_mahjong_g] auto
                            input_map[p8_mahjong_h] auto
                            input_map[p8_mahjong_i] auto
                            input_map[p8_mahjong_j] auto
                            input_map[p8_mahjong_k] auto
                            input_map[p8_mahjong_kan] auto
                            input_map[p8_mahjong_l] auto
                            input_map[p8_mahjong_m] auto
                            input_map[p8_mahjong_n] auto
                            input_map[p8_mahjong_pon] auto
                            input_map[p8_mahjong_reach] auto
                            input_map[p8_mahjong_ron] auto
                            input_map[p8_mahjong_score] auto
                            input_map[p8_mousex] auto
                            input_map[p8_mousey] auto
                            input_map[p8_paddlex] auto
                            input_map[p8_paddley] auto
                            input_map[p8_pedalbrake] auto
                            input_map[p8_pedalgas] auto
                            input_map[p8_pedalother] auto
                            input_map[p8_stickx] auto
                            input_map[p8_sticky] auto
                            input_map[p8_stickz] auto
                            input_map[p8_trackballx] auto
                            input_map[p8_trackbally] auto
                            input_map[safequit] auto
                            input_map[service_coin5] auto
                            input_map[service_coin6] auto
                            input_map[service_coin7] auto
                            input_map[service_coin8] auto
                            input_map[ui_toggle_ui] auto
                            input_steadykey no
                            lcd_server none
                            lcd_speed 4
                            lcd_timeout 500
                            misc_bios default
                            misc_cheat no
                            misc_cheatfile cheat.dat
                            misc_difficulty none
                            misc_eventdebug no
                            misc_eventfile event.dat
                            misc_freeplay no
                            misc_hiscorefile hiscore.dat
                            misc_lang none
                            misc_languagefile english.lng
                            misc_mutedemo no
                            misc_quiet yes
                            misc_safequit yes
                            misc_smp yes
                            misc_timetorun 0
                            record_sound yes
                            record_sound_time 15
                            record_video yes
                            record_video_interleave 2
                            record_video_time 15
                            script_coin1
                            script_coin2
                            script_coin3
                            script_coin4
                            script_emulation
                            script_event1
                            script_event10
                            script_event11
                            script_event12
                            script_event13
                            script_event14
                            script_event2
                            script_event3
                            script_event4
                            script_event5
                            script_event6
                            script_event7
                            script_event8
                            script_event9
                            script_knocker on(kdb, 0b100); wait(!event()); off(kdb, 0b100);
                            script_led1 on(kdb, 0b1); wait(!event()); off(kdb, 0b1);
                            script_led2 on(kdb, 0b10); wait(!event()); off(kdb, 0b10);
                            script_led3
                            script_play
                            script_safequit
                            script_start1
                            script_start2
                            script_start3
                            script_start4
                            script_turbo while (event()) { toggle(kdb, 0b100); delay(100); } off(kdb, 0b100);
                            script_video wait(!event()); set(kdb, 0);
                            sound_adjust auto
                            sound_equalizer_highvolume 0
                            sound_equalizer_lowvolume 0
                            sound_equalizer_midvolume 0
                            sound_latency 0.05
                            sound_mode auto
                            sound_normalize no
                            sound_samplerate 44100
                            sound_samples yes
                            sound_volume -3
                            sync_fps auto
                            sync_resample auto
                            sync_speed 1
                            sync_startuptime auto
                            sync_turbospeed 3
                            ui_color[help_other] 000000 808080
                            ui_color[help_p1] 000000 ffff00
                            ui_color[help_p2] 000000 00ff00
                            ui_color[help_p3] 000000 ff0000
                            ui_color[help_p4] 000000 00ffff
                            ui_color[interface] 000000 ffffff
                            ui_color[select] 000000 afffff
                            ui_color[tag] 247ef0 ffffff
                            ui_font auto
                            ui_fontsize auto
                            ui_helpimage auto
                            ui_translucency 0.8
                            • FlightRiskF
                              FlightRisk @caver01
                              @caver01 What about mapping an xbox 360 usb controller with 2 sticks and using the push to click feature on the right stick to fire? Not sure if that would cause you to maybe move the stick while trying to press it and throw off your aim. In that case, the right trigger would probably work great. Do you know how I would try that? Is it like retroarch where I just go in and move the sticks and press them as I go through options, or do I need to edit a text file? Your example above of mapping a "tank stick", is that just moving the stick around or typing those word in?
                              • FlightRiskF
                                @mediamogul I found the same bezel you show in your post for battlezone. It is a .png with dimensions of 1647x955. Very odd size. It that what I want and advmame takes care of sizing, or should I pull it into photoshop/gimp and resample it to my monitors native 1920x1080? Things might be off a bit since these are different aspect ratios. 1.7246 vs. 1.7777
                                  @flightrisk
                                  Try changing display_expand 1.25 to display_expand 1.0
                                  I found the same bezel you show in your post for battlezone... It that what I want... ?
                                  If you plan on using AdvanceMAME, you need to use an artwork file specifically formatted for it. Try using the bzone.zip artwork file located here.
                                  • caver01C
                                    caver01 @FlightRisk
                                    If you have triggers that are easier, I would recommend that over the push-click, but that is just me. I think push-click is hard to execute while keeping the stick in a specific position.
                                    Editing digital inputs for AdvanceMAME is best done from within MAME itself by pressing TAB on a keyboard. This will bring up a pop up menu and you can navigate to the controls configuration menu choices. When you select an input to map, you should be able to press buttons on a controller to map them.
                                    To do this mapping, you are moving the stick or pressing D-pad. To do a <NOT> entry, you have to double-tap in the given direction. To make the inputs <AND> together you do them at the same time, or right after each other (but before the input is accepted). To <OR> them together, you do one input, let it accept, then immediately do another on the same line. I if you move to a new line and back, it will overwrite the whole entry instead.
                                    Analog sticks introduces a potential new issue that I have not tested. If these movements are not accepted, you may need to define these manually by setting up analog inputs in the .rc file. For this you would need to know the indexes of your sticks. This is not a trivial process, as you would probably want to use the advj utility to test. You can read about the details here.
                                    FlightRiskF 1 Reply Last reply Reply Quote 1
                                    • caver01C
                                      caver01 @FlightRisk
                                      @flightrisk Regarding artwork, bezels etc, you really cannot just use a .png file. You have to use the MAME .106 artwork format as mediamogul mentioned. The zip files for this old menthod will contain overlays, bezels and background files alongside a .art text file that describes exactly how this version of MAME should apply them. When you download an appropriate .zip for the rom in question, most of these details will have been already worked out.
                                      • FlightRiskF
                                        FlightRisk @caver01
                                        @caver01 Excellent! I have it working exactly the way I want. Thanks for the tip on how to enter a <NOT>. It works well. In the end, I settled on left analog up and down, right analog up and down, and right trigger for firing. I left the keyboard options in as well. And you are right, push click just won't work in this game. My trick on my arcade game was to back up a lot while doing little turns to get distance between myself and the other tank to have time to react to their firing. Then go after them, often going past them very close and watching the radar to backup again, turn and fire. The only problem with this strategy is when you are backing up and hit an obstacle just as they fire ;)
                                        • FlightRiskF
                                          @mediamogul That is exactly the artwork I found and was asking about. I can see positions mapped out in the .art file. I was just confused about the odd resolution
                                          • FlightRiskF
                                            @mediamogul - Thanks so much for the help. Almost there. Changing the display parameter from 1.25 to 1.0 made it look 4:3 now, but here is my screen with the bezel installed. It is cutting off the right and left, and it is clearly zoomed out too much since it is cutting off the top and bottom. So it looks like it not only is zoomed in, but cutoff for a 4:3 monitor instead of my 16:9
