Help with moltengamepad please
Re: Help Mapping Wii Classic Controller to Retropie #mapping help
I as far as sudo nano and just get a black and white screen with GNU NAN0 2.2.6
I've copy the txt into it but don't know what to do next.
Thank you for your help and time -
@welshwisdom Ctrl+X is the key combo when you're finished editing (the key combos are listed along the bottom of the window). When you do this, it will ask if you want to save, so press the Y key to confirm. Then it will ask where you want to save the file. Depending on what instructions you're using, you should have done something like
sudo nano /home/pi/mywminput
, which is the path and filename for the file you're creating. If you did this, you can just press Enter when it asks you where you want to save, because you already typed the filename. If you just didsudo nano
though, you'll need to type where you want the file to go into the field that comes up.
