    Analog stick help
    analog sticks
    4 Posts 2 Posters 1.8k Views
    • Z
      zero2k
      I have a raspberry pi 3 and I'm using a 8bitdo sn30 pro Bluetooth game pad. It seems to work with just about every system. The only problem that I'm having with it is I can't get the analog sticks to work on N64 games and psx games and some of the psx games the controller doesn't work at all such as mega man x4 and legend of dragoon. I've tired launching a psx game and pressing the select and X buttons to bring up that menu and switching from standard to analog but no luck. I don't know if this helps but when I first load a psx game it says the controller is on port 0 and in that menu there is no port 0 it starts at port 1. Any help would be greatly appreciated.
      BobHarrisB 1 Reply Last reply Reply Quote 0
      • BobHarrisB
        BobHarris @zero2k
        @zero2k In the controls setting you can only set device type to Retropad w/ analog when a ps1 game supports analog control. Most ps1 gamesdo not support this and the pad will be unresponsive. I still play these games with the thumbstick though: In the same menu under Device type it says: Analog to digital. Change that option to Left analog. Hope this helps.
        Pi 3B , 64 GB Sandisk ultra flashdrive, 19 systems, 872 hand picked classic gaming gems :-) Dual shock 4v2
        • Z
          zero2k @BobHarris
          @bobharris thanks I'll try it, do you think it would work if I used a different controller such as a PS3 controller ?
          • BobHarrisB
            BobHarris @zero2k
            @zero2k Shouldn't make a difference.
