    I can not use a 5inch lcd
    18 Posts 6 Posters 10.2k Views
    • glennlakeG
      glennlake @caffecomborras
      @caffecomborras We can't read your file correctly when it is just cut and paste. Please read "https://retropie.org.uk/forum/topic/3/read-this-first" and "http://commonmark.org/help/". Those hashtags are very important as any line that starts with in is ignored by the program.
        caffecomborras
        It is the first time I use a forum to get doubts. I did as you said and still did not work
          caffecomborras
          I solved a problem but now I have another. the already image appears on the screen . but it appears only in half of the screen. http://postimg.org/image/8wrxbrl0r/
          someone can helpme?
          glennlakeG caver01C 2 Replies Last reply Reply Quote 0
          • glennlakeG
            @caffecomborras Here is a link to a youtube video that explaines the setup of your 5 in screen "
            ". It looks different because it gets it power from the gpio pins but the setup is the same. I don't use the touch screen so all I did is add these 3 lines to the bottom of the file /boot/config.txt.
            hdmi_group=2
            hdmi_mode=87
            hdmi_cvt 800 480 60 6 0 0 0
            I haven't tried the touch screen so I don't know how that works.
            Hope this helps
            • caver01C
              caver01 @caffecomborras
              @caffecomborras said in I can not use a 5inch lcd:
              someone can helpme?
              Also, your screenshot has a rainbow box in the corner. Your Pi is under powered. The rainbow colored box indicates low voltage.
                caffecomborras
                Thank you all for your help . finally after many attempts succeeded. thank you so much
                glennlakeG A J 3 Replies Last reply Reply Quote 0
                • glennlakeG
                  @caffecomborras Congratulation! Glad we could help. We have all gone down this path. Some of us have just traveled farther than others.
                    Alessio @caffecomborras
                    I have the same problem with the same screen. Can you please explain me how you solved? I have modified the config.txt but without success...
                      Alessio
                      Solved! Many thanks to all
                        juankaever @caffecomborras
                        @caffecomborras
                        Hi, i have the same problem with my screen, I search in a lot of sites, but the size is correct, but the color is strange, tell me please how you resolved this???
                        I read the guide retropie, but i try all combination, and I got teh result of yours pics.
                        Thanks, please respond.
                          rxone
                          @juankaever
                          for 5 inch LCD
                          edit on /boot/config.txt.
                          search, replace and add this
                          hdmi_group=2
                          hdmi_mode=87
                          hdmi_drive=1
                          save and try boot again
