    games/emulators wont work pls help
    roms dont worknothing works
    7 Posts 3 Posters 1.1k Views
    • H
      Hovnou787
      ive installed retropie to a micro sd card i have the raspberry 3 i installed the right type and everything but games wont show up ive put the digdug rom zip file on a usb under the nes tab in the directory that was made by the device i restarted the emulator and still 0 games and the ony option i have on the screen is the "configuration" tab
      • rbakerR
        rbaker @Hovnou787
        @hovnou787 Always https://retropie.org.uk/forum/topic/3/read-this-first
        If games do not show up, you have either placed them in the wrong folder or you have placed them in the correct folder but the file format is incorrect or not compatible. Emulators only show up once you add the correct roms.
        https://retropie.org.uk/docs/Nintendo-Entertainment-System/ - Accepted File Extensions: .zip .nes .smc .sfc .fig .swc .mgd - Make sure your roms have headers. Roms without headers will not work.
        Have you placed them in /home/pi/RetroPie/roms/nes?
        When you say this, it sounds to me that the roms have not been transferred to the Pi. Post more info as requested detailing your actions exactly.
        P.S. (Headers are not part of the original game's data, and are only present to tell emulators how to properly run a ROM image)
        • H
          Hovnou787
          im doing this from my mac and downloaded the zip file from [removed by admin]and i followed instructions from a YouTube video on the channel TheGeekPub i noticed that when i started it up his had options other than the configuration tab i didnt
          • herb_fargusH
            herb_fargus administrators @Hovnou787
            @hovnou787 read the forum rules.
            And follow the official docs. Not some random YouTube channel.
            • H
              Hovnou787
              sorry about that I'm kinda in a rush and i just need help with where i can download those zip files to put on my pi ill read the rules rn
              • H
                Hovnou787
                ... nvr mind
                • rbakerR
                  rbaker @Hovnou787
                  @hovnou787 said in games/emulators wont work pls help:
                  https://retropie.org.uk/forum/topic/2/forum-rules
                  I'm kinda in a rush
                  Retropie requires you to read the instructions that are comprehensively written and it's not a boot and play solution. If you have no time, it's the wrong project for you. 99% of all your questions are covered in those docs.
