    Xbox360 wireless controllers - receiver connectivity issues
    56 Posts 29 Posters 61.5k Views
    • pommeP
      pomme
      Getting good results so far with most recent commands posted. Thanks you! This was driving me crazy!
        UDb23 @trixter1981
        @trixter1981 thanks for posting this downgrade script.
        I'll try it to solve the Logitech controller not working issue after 3.8 update.
        Did you report the kernel problem on Github ?
        I would do it but I'm not skilled enough to technically explain this kernel problem.
          rossoe
          Can you please tell me what I'm doing wrong here with permissions?
          First line works ok:
          sudo curl 'http://pastebin.com/raw/e2ZKSMr1' -o 'patched_rpi-update.sh' -L -B
          % Total % Received % Xferd Average Speed Time Time Time Current
          Dload Upload Total Spent Left Speed
          100 11038 0 11038 0 0 90959 0 --:--:-- --:--:-- --:--:-- 91983
          Then I have trouble with:
          sudo tr -d '\015' < patched_rpi-update.sh > /usr/bin/rpi-update
          -bash: /usr/bin/rpi-update: Permission denied
          which means I get the certificate errors carrying on with the further commands.
          pommeP 1 Reply Last reply Reply Quote 0
          • pommeP
            pomme @rossoe
            @rossoe said in [Xbox360 wireless controllers - receiver connectivity issues]
            I got this error too. Make sure you are logged in as root user. You may need to create a root user account.
              raelik @pomme
              @pomme Yeah, I should have mentioned you should run sudo su - (to switch to root) before doing any of this. Fixed my post (again).
                rossoe
                worked perfectly thank you.
                can we easily upgrade to the newly released 3.8.1 without the kernel jumping back up to the broken version?
                • trixter1981T
                  trixter1981
                  done the upgrade to 3.8.1, it's okay. The kernel is untouched.
                  • Z
                    zanie420
                    RPI 3
                    Retropie 4.0-dev
                    Having the same issues getting wireless 360 receiver to work consistently after fresh install and enabling xboxdrv via the script. Tearing my hair out! No output from jstest /dev/input/js0.
                    However, I too can get it to work by logging into SSH as root and using:
                    killall xboxdrv
                    xboxdrv --trigger-as-button --id 0 --led 2 --deadzone 4000 --silent & sleep 1
                    This didn't work until I blacklisted xpad and installed xboxdrv via apt-get
                    Randomly the controller stops working and you have to redo it. Restarting puts you back a square one, but the workaround IS consistent it seems.....
                    What the hell am I doing wrong?
                      backstander @zanie420
                      @zanie420 if you read down below my post (trixter1981 & raelik posts), there is a workaround that will downgrade the kernel. The xboxdrv seams to work pretty consistently after this downgrade.
                        ataritoday
                        Hi All,
                        Apologies, another Newb.....
                        I tried the script in above...sudo worked, curl worked and it downloaded something...
                        hard to tell if tr-d worked or not.....
                        same with chmod , did not seem to do much, but no error either....
                        when I get to the line /usr/ line I get a syntax error.... is this suppose to be a continuation of the line above ? what does it do ?
                        Apologies for the basic questions.
                        Thx
                        Jim
                          mazjohn
                          Another Newb when it comes to installing scripts and Linux Kernels, ..cannot get past the first part without errors so far... Attempting this on clean install of V3.81 , over an hour struggling... will keep trying.
                          I would hope there would be an updated image release soon that officially addresses this??
                          Update: I gave up. had to start over with a clean install of retropie V 3.6 which uses an older Kernel. Works fine now.... Hopefully there is an update soon that addresses out of box issues with 3.81.
                            sberrieman
                            Hi,
                            I'm getting a gzip error when running the final command and it performs the rollback - any ideas?
                            • N
                              NizZ8 @raelik
                              @raelik Thanks for posting, fixed the issue for me with a fresh install of 3.8.1
                              • herb_fargusH
                                herb_fargus administrators
                                An issue has been logged here: https://github.com/raspberrypi/linux/issues/1540
                                  PhantombrainM
                                  Thank you. This worked so far.
                                  But one question for the future: how to roll back?
                                  apg-get update and upgrade does not install the newest kernel anymore.
                                  How do I switch back to an upgrading distribution when the problems have been fixed?
                                  regards PhantombrainM
                                    dabone
                                    I'm trying to get a fresh install using my dp9 gpio controllers along with my wireless xbox 360 controllers.
                                    I guess I'm outta luck at the moment? I tried a fresh install, then backing down the kernel, but then I can't install the gamecon driver.
                                    Later,
                                    dabone
                                      Jexoteric
                                      The script above works well, but it didn't fix the flashing ring of lights that would normally indicate the controller is still trying to connect. Shouldn't the light switch to the corresponding lighted quadrant that the receiver sees the controller as (1-4)?
                                      Is the flashing ring the normal behavior or is something still incorrect?
                                        backstander @Jexoteric
                                        @Jexoteric
                                        I'm not sure if you already did this step but...you'll still need to setup the Xbox 360 controller in the RetroPie Setup Script. This should setup the correct "corresponding lighted quadrant" to light up.
                                        https://github.com/retropie/retropie-setup/wiki/Setting-up-the-XBox360-controller
                                          Jexoteric @backstander
                                          @backstander nailed it. LED's work now, and are much less annoying.
                                            Arcuza
                                            I'm having issues with this as well. It seems like random results, sometimes it works, sometimes it doesn't. Sometimes LEDs are flashing, sometimes they show contoller#, sometimes they die.
                                            Is there a working fix? Will a fix be available in the next version?
                                            I'm running 3.8.1 with raspberry PI 3.
