    Can I Scrape to my USB stick with Selphs scraper?
    scraper
    29 Posts 10 Posters 8.2k Views
    • FlightRiskF
      FlightRisk
      It is all clear to me and working now, so thanks to everyone. I think the Wiki should have a warning box that creating a USB drive with a "retropie" folder is very, very different that creating one with a "retropie-mount" folder. I made a retropie folder on the USB days ago and thought I was running RetroPie on the SD card and the roms from the USB. Instead, as was pointed out here, it was just copying the roms on the stick to the SDcard. Pull the stick after it loads them up and things still work. Creating a "retropie-mount" folder copies all of retropie, files, images, roms, etc. from the sdcard to the USB drive and runs it all from the USB. The USB overrides the sdcard version of retropie as long as it's plugged in. Take the USB out and the last version of what was on the SDcard works just fine. Remove retropie and all the roms from the sdcard, and then the USB drive must be inserted to play the games.
      If something goes wrong after plugging in the USB drive during the conversion (like shutting down before the migration is finished) , you can just delete the retropie-mount folder and stick it back in the Pi. It will automatically start copying again. I hate there is no progress indicator anywhere. This service runs in the background. And while I always buy USB drives with led indicators, this time I didn't realize I was buying one without. What a pain. I watch the green light on the Pi and run a "df" on it every half hour or so (had over 1400 roms with scrapes) and watch to see the bytes used keep going up. When it stops changing for a while, I'll know it is finished (or locked up ;) ) So another big red box that should be in the Wiki is "This process runs in the background and you will have no indication of whether it is finished unless ... <fill out the rest>"
      herb_fargusH dankcushionsD 2 Replies Last reply Reply Quote 0
      • herb_fargusH
        herb_fargus administrators @FlightRisk
        @flightrisk said in Can I Scrape to my USB stick with Selphs scraper?:
        I usually monitor it over ssh as I don't have any fancy flashy usb sticks either
          dankcushions Global Moderator @FlightRisk
          i mean, the guides for the two things are on entirely different pages. i don't know what the warning would achieve. it's like us saying "don't do something that we haven't told you to do here" :)
          FlightRiskF 1 Reply Last reply Reply Quote 0
            ChuckyP
            Quick question. When using the RetroPie-Mount on an external 1TB drive it takes a little over 3 minutes to boot from the emulationstation logo screen.
            I had previously used another solution and it didn’t take much longer than using just the SD card.
            I have the full PSX and SegaCD collections so there is a ton of data (more than 800gb in all). Has anyone seen this on their setups?
            Pi3, RetroPie 4.3
            stooS 1 Reply Last reply Reply Quote 0
            • stooS
              stoo @ChuckyP
              @chuckyp Yeah... gonna play all those games are you?
              Love a bit of Mary-Kate & Ashley: Magical Mystery Mall?
              Can't wait to get back to Barbie: Explorer?
              Going to unleash your creativity in Make My Video: Marky Mark and the Funky Bunch?
              I'm trying my best to be polite here: maybe a more curated collection would be a good idea?
              In all seriousness: https://github.com/RetroPie/RetroPie-Setup/wiki/FAQ#why-does-shut-down-and-reboot-take-ages
              Try turning on Parse Gamelists Only so it doesn't scan for new ROMs at startup.
                ChuckyP @stoo
                @stoo I’ll try your suggestion. And I’ve played the hell out of Babie explorer by the way. :-)
                • FlightRiskF
                  FlightRisk @dankcushions
                  @dankcushions Because people google something like "copy roms to USB" or "run roms from USB" and you read a link that seems to give you the answer, but it trips you up because it is not clear, you miss something, or there isn't a link to other options. Just the distinction between the words "transfer", "copy", "run from USB" can mean different things to different people. "Transfer" to me meant transferring my games to the USB to run there. Instructions in 2 different places that say to create a folder called "retropie" or "retropie-mount" and it lets you use roms on a USB are very similar. One could even think one is a revision in a later version. And you are at the luck of the draw in your google search as to which one you get.
                  I am an engineer and owned an arcade in the 80's and 90's, not a completely unintelligent guy (though maybe slipping in my middle age ;) ) and I got it wrong. Not all of us PC folks are as fluent in Linux and emulation is a very complex and convoluted hobby just by nature of a bunch of volunteers working with many different open source pieces. I deal with going to resources like the MSDN every day because I write code directly to the low-level Windows API, and they all have "see section xxx for related info". The API for the low level audio drivers and multiple conflicting speech APIs for one, remind me of this confusion over two different features of "automagically" doing things with roms using a USB drive. Something like, "Don't use this function to run roms from the USB drive, this is just a method to transfer roms from a PC to the Pi. If you are trying to actually run your emulators and roms from the USB drive instead of the SDcard, use the instructions in section xxx" and a cross link from there back would be helpful, IMHO.
                  And you guys can do as you will, it is just a suggestion. I'm just trying to answer the question you asked and hopefully see how things to someone not as knowledgeable as you can become confused. I researched this for a few hours googling into several forums and what also tripped me up is that there are a lot of other people getting confused and passing along the wrong information. You can see where people are using the wrong folder name for what they are trying to do.
                    dreamtear
                    Old thread, but this is what i did.
                    Once the usb is setup and all files have copied move the scraper files to the retropie-mount folder on the USB.
                    mv ~/.emulationstation/downloaded_images /media/usb/retropie-mount/
                    mv ~/.emulationstation/gamelists /media/usb/retropie-mount/
                    Since retropie automounts the items in the retropie-mount dir into the ~/RetroPie/ dir we can create symlinks to point the that ~/RetroPie/ and no need to change the sources in the files.
                     ln -s ~/RetroPie/downloaded_images/ ~/.emulationstation/downloaded_images
                     ln -s ~/RetroPie/gamelists/ ~/.emulationstation/gamelists
                    mituM 1 Reply Last reply Reply Quote 1
                      mitu Global Moderator @dreamtear
                      This post is deleted!
