    help with usb controller
    genesis buttonsgenesis controlmappingusb controller
    8 Posts 3 Posters 1.7k Views
      arj5193
      i know you get this alot but i changed everything i can think of. my usb 6 button genesis controller isnt registering i changed to the 3 to 6 button and changed the inputs to 513 and nothing. i cant get to the quick menu because theres no select button and when i push a theres no option for the controller. HOW DO I GET THE C BUTTON AND Z BUTTON. its driving completely insane i cant figure it out!
      mituM edmaul69E 2 Replies Last reply Reply Quote 0
        mitu Global Moderator @arj5193
        @arj5193 If you're in Emulationstation, press Start to get to the menu and you'll be able to choose 'Input' from there. Unless you left out the Start key from the input mapping ...
          edmaul69 @arj5193
          @arj5193 setup the controller in emulationstation. hit the mode button when it asks for select and hotkey. remove the 513 setting. not sure where you got that number from.
            arj5193
            i will try a hyperkin gn6
              arj5193 @edmaul69
              @edmaul69 input_device_p1 = "513" or the change from 3 to 6 button pad in configs not working anymore? also the input menu doesnt have c or z. its only giving a b x y etc.. i have no mode button which im ordering one with it
                edmaul69 @arj5193
                @arj5193 it isnt done that way anymore. Set your device back to default. The mode button doesnt work either. You have to go into retroarch gui while in a game and then go into quick menu, options. In there you change it from 3-6 button controller or auto.
                  arj5193 @edmaul69
                  @edmaul69 ok explain how do i get in the retroarch gui and quick menu. i launch the game they say press A for options but theres nothing in there saying 3-6 button or atuo is there a command line i can do?
                    edmaul69 @arj5193
                    @arj5193 once you get into the game press your hotkey & X at the same time.
