    sfc30 causing problems!!!
    pi3 retropiesfc30
    1 Posts 1 Posters 411 Views
      kmcl
      I have successfully paired both my sfc30 controllers with with my pi3 and they connect everytime i switch on so all good there the problem i am having is everytime i switch on it asks me to configure buttons and on top of this will only work through certain games when wired and not at all when wireless any ideas.I have so far tried to remove ps3 drives as that was a suggestion on here and that helped them connect better but still no luck using them in the emulation station. I have seen people speak about configuration in es how do you do this is it just start > configure input > map buttons or is there more i should be doing.
