    FFIX some code doesn't work properly
    action replaycodepsx-rearmed
    2 Posts 2 Posters 636 Views
      TitQuentin
      Hi all !
      I would like to replay FFIX with all the items in the game. So I found the code that would allow this, but only it doesn't work properly.
      Indeed I have only 99 copies of the hammer.
      Here is the .cht file that I created:
      https://pastebin.com/00GU9J14
      Note : Max Gils work for exemple.
      I use lr-pcsx-rearmed r22 and FFIX French Pal Version format .PBP
      Can you help me please?
      Thx for help.
        RoutineInsanity
        @TitQuentin said in FFIX some code doesn't work properly:
        -pcsx-rear
        I'm having a very similar issue with FFVIII but can't seem to get any help on the boards. Did you ever figure yours out?
