    Incorrect 4:3 aspect ratio help:
    aspectratioresolutionhelp
    8 Posts 4 Posters 5.7k Views
    • LoggaheadL
      Loggahead
      I need some help on aspect ratios in retroarch. I am running a 1280x1024 lcd on my pi via an hdmi to vga converter. Everything works fine in emulation station and runs fullscreen. However, when I run a retroarch emulator , it's not running fullscreen. Instead, I have some very small black lines at the bottom and top of the screen.
      As an example, lets use lr-mame2003 and lr-fba under the arcade folder. If I use Select + X to edit the retroarch.cfg to a custom resolution of 1280x1024, everything is fine as long as the game was a 4:3 game. However, when I run a game such as Pacman, it stretches it instead of maintaining it's aspect ratio. See the pics below. Setting the aspect ratio to either 4:3, config, or core provided all produce the small black lines. Custom at 1280x1024 like i mentioned above and 5:4 ratio does not.
      Any ideas? I didn't change any settings, this was all happening on a clean install.
      My 1982 Robotron Restoration / Conversion Project running on retropie !!!
        ChuckyP
        I can’t tell from the photo. But you may want to turn off “Integer Scaling”. It should be just under the options you have shown on the photo.
        EDIT: Sorry. Looks like it is off.
        • LoggaheadL
          Loggahead
          Because it fills the whole screen when i select 5:4 ratio makes me feel like retroarch isn't properly recognizing my actual screen resolution. Should I try and manually set the resolution somewhere and where would I do that? I already tried the configuration editor and set the resolution for all libretro emulators but that didn't do anything.
            dankcushions Global Moderator
            @loggahead said in Incorrect 4:3 aspect ratio help::
            1280x1024
            this isn't a 4:3 aspect ratio. 4/3=1.333. 1280/1024=1.25.
            it's slightly narrower, which is why you get borders at the top and bottom.
            • LoggaheadL
              Loggahead
              Ah!!! Dumb dora! I never really did the math, just always thought those PC resolutions were 4:3.
              Hmmm... So the black bars top / bottom are the actual true aspect ratio of the game and if I force 1280x1024 I will be slightly stretching them vertically. That also means that if I am ok with that and force that resolution, there's no easy way for me to avoid stretching vertical (portrait) games like pacman?
                dankcushions Global Moderator @Loggahead
                if you use 'core provided' aspect ratio (the default), pacman will not be stretched. by setting it to '4:3' you are telling all games to be 4:3 regardless of whether they are or not :) 'core provided' in lr-mame2003 will mean every game appears in their correct aspect ratio.
                • LoggaheadL
                  Loggahead
                  Makes sense and that's what I thought the answer would be. Thanks again.
                  • N
                    nasp2000
                    Yap, when i use Retroarch, i always choose "core provided" and any screen or device the resolution of the game is always OK.
