    HELP! Retropie Does Not Fully Shut Down
    shutdowntriggerhappyhotkeypigrrl 2
    5 Posts 3 Posters 1.4k Views
    • velkhapnV
      velkhapn
      Hello,
      I'm trying to build a pigrrl 2 from Adafruit's instruction. Everything has gone well so far until I tried shutting down. I followed: Start > Quit > Shutdown System > Yes. The pi froze in the terminal with the last line was:
      [ ok ] Stopped LBS: triggerhappy hotkey daemon
      It happens everytime I try to shut down. The green light flashes for a few seconds and stops. The red light remains on. I tried shutting down through ssh with the commands: "sudo shutdown -h now", but it also stopped at the same line above.
      Pigrrl 2 uses a customized controlling set-up similar to SNES controller, so I don't know if disabling triggerhappy is a good idea. I figure I would need the hotkeys to exit the rom with START+SELECT. I have updated retropie and retropie script, but the problem remains. Roms can be run and they work properly as expected. I set SELECT as "Hotkey enable". Buttons work!
      Can anyone help me how to fix this and safely shut down the pi? I feel as if I'm killing the pi with the power switch to directly cut power before properly shutting down.
      Pi Model or other hardware: Raspberry PI 2B
      Power Supply used: Lithium Ion Polymer Battery - 3.7v 2500mAh/ Powerboost 1000c
      RetroPie Version Used: 4.3
      USB Devices connected: edimax wifi
      Controller used: customized keypad by adafruit for Pigrrl 2
      Error messages received: NONE - Shutting down process stopped at "[ ok ] Stopped LBS: triggerhappy hotkey daemon"
      Guide used: https://learn.adafruit.com/pigrrl-2/software
      Emulator: Emulationstation
      Thank you!
      • rbakerR
        rbaker @velkhapn
        @velkhapn said in HELP! Retropie Does Not Fully Shut Down:
        3.7V?
        velkhapnV 1 Reply Last reply Reply Quote 0
        • velkhapnV
          velkhapn @rbaker
          @rbaker Hi! Yes, the battery came with the Pigrrl 2 kit.
          • rbakerR
            rbaker @velkhapn
            @velkhapn A raspberry Pi 2 requires a 5V power supply.
            • jonnykeshJ
              jonnykesh @rbaker
              @rbaker The kit from adafruit comes with a boost converter that converts the 3.7V up to 5V.
